removing shift knob
greasemonkey060
removing shift knob
Post by greasemonkey060 »
question, how the h*ll do i get the damn shift knob off??
ive got a 71 f250 auto, so its on the column, its all original and i dont want to scratch the chrome..anything helps!
thanks
-brandon
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
FORDification
Site & Forum Admin
Site & Forum Admin
re: removing shift knob
Post by FORDification »
You mean you want to take the knob off the end of the shifter arm? I'm not sure it can be easily removed, to be honest with you. Why do you want it off?
It's probably pressed on, so removing it is going to be a major PIA without damaging the shifter arm. If your knob is damaged, I'd say just replace the entire arm...might be a little easier. All you have to do is tap out the roll pin holding it to the shift collar, and the whole arm comes right out.
boots
Post by boots »
on the shifter right? mine screws off.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
greasemonkey060
Re: re: removing shift knob
FORDification wrote:You mean you want to take the knob off the end of the shifter arm? I'm not sure it can be easily removed, to be honest with you. Why do you want it off?
well i was wanting to put on an aftermarket knob, just for looks, stock looks good, but wouldnt mind some customization..
after looking at some catalogs, i noticed they only sold the knobs with the arm, so i think it might be a lost cause without replacing the whole are anyway..
-brandon
'67 F100 SWB STOCK.
