clean up
- customcrewcab
clean up
well did alittle sandbasting and cleanup. need to do some more and weld up some hole. take a look. this is why if you going to change out your front you use a mustang II. tons of room, no steering box and it looks pretty clean.
![Image](http://www.fordification.com/images/forum/ty.jpg)
re: clean up
looks good. you should be so kind to take measurements of the crossmember and stuff.
That is going to be sweet! I love low trucks. I have a Mustang II setup on my '48. I love it, tons of room, disk brakes, rack and pinion steering - life is good.
"Smoke me a kipper, I'll be back for breakfast"! - Ace Rimmer
1972 Donor "Green Monster" F100 Custom
1971 F100 Ranger XLT
1987 Corvette
1976 Datsun 280z
1948 Chevy Fleetline Aerosedan
http://www.fordification.com/galleries/ ... ?cat=10449
1987 Corvette
1976 Datsun 280z
