well got my rear brakes figured out. add 13" rotors with 6 pistion calipers. ran into some problems with clearance so i had to have the centers turned out and add 3" hats. also added some huge brackets to the housing
but i think it turned out pretty good.
rear brakes finished
- customcrewcab
![Image](http://www.fordification.com/images/forum/ty.jpg)
- GT-Racer
