See if this helps you....
You must be logged in to see this..
fusable links
- cobraF100
re: fusable links
Chris
Never Forget Our Soldiers
![Image](http://www.fordification.com/galleries/albums/userpics/10003/thumb_20%25.JPG)
- bluef250
re: fusable links
Check out these 2 ebay items.
1972 72 FORD F PICKUP FULL COLOR WIRING DIAGRAM
Item number: 7949660397
1972 FORD WIRING & VACUUM DIAGRAMS MANUAL - MUSTANG, THUNDERBIRD, TRUCKS, ALL MODELS Item number: 7933939090
http://www.hotrodssuperstore.com/index.html - They have a CD with manuals and wiring for about $50.
Also need to trace the wire to switch or connection and find the short. Start with the ground and work backwards. Of course you need the wiring to do that.
Good luck. Phil
Good luck. Phil
- cobraF100
re: fusable links
See if this one is a Better view...
Must be logged in to read or see:
Chris
