Hi All;
So with all this stuff going on with the Corona Virus going on and the world going to hell in a handbasket , I find myself initially working from home and maybe a potential layoff depending on how long this economy tanks. I've decided that I have a bit of time to get back to work on the rebuild.
I am changing my 1967 base cab into a Ranger model with a lot of the accompanying Ranger trim although not always year correct to my '67. Anyhow , since my base didn't have the Ranger emblem on the bed I am looking to see if anyone might have the correct pin hole locations for each side so that I can drill the proper holes. Maybe dimensions from the upper bump seam and say the tail light extender seam. I did a search and nothing came up. I did find a schematic for the location of the car door mirrors in the tech section as my doors had the western mirrors.
Thanks in advance
Ranger Bed Emblem Location
- beejaytx225
Re: Ranger Bed Emblem Location
Maybe this will help? I'll measure it when the rain stops.
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Family nicknamed her "Bethany"
Central Texas
Past Ford's: 1994 Ranger, 2008 Ranger, 1991 Ranger, 1985 Mustang, 1968 SB Custom Cab F100, 1998 Explorer.
Current Ford's: 2011 Ranger, 2006 Expedition, and of course Bethany
360 w/C6
Peacock Blue
Central Texas
Yes. Thank you for the pic. That does help a little bit. What's that like an 1" , 1.25" from each seam?
- beejaytx225
Looks to be about 1.75" from rear body line.
And about 1.5" from lower body line You do not have the required permissions to view the files attached to this post.
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- beejaytx225
If you need the measurements for the holes that need drilled in the bed let me know.
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
That's awesome. Thanks so much. I really appreciate it.
And if you mean the actual hole locations for each side , that would be perfect.
If you mean where the pins are on the emblem , I have the re-popped emblems so I can hopefully, correctly do the math.
