Engine and Trans ideas?
Hi Everyone!
I haven't been on here in ages as i haven't had time to even look at my truck recently
I have a 67 long bed F100 with a straight 6 and 3 on the tree.....my question to all you experts is what i should do for a engine/trans?
I'm very tall so i find it hard to use a clutch in an f100 if driving longer than a few minutes....so was hoping for an auto, especially because i want it to be more than a drive 6 times a year truck.
Id appreciate any advice on what you guys think would be an easy-ish swap without being way too expensive....i don't want anything performance, so im actually happy to keep the straight 6 if that makes it easier.
Thanks in advance everyone!!!!
Re: Engine and Trans ideas?
If you're happy with the 6 then just swap an auto trans in - find the correct steering column, pedals, and the all the linkage and change it over........my on what to do...... ........I'm 6 feet tall and also don't really like the pedal placement on mine but just decided since mine was a low mile almost original truck i would just deal with it.......
1997 Honda CBR 900RR
- jzjames
Agree. 300 I6 with a C4 auto is a great ride.
Agree C4 should be plentiful and if you’re even a little handy you can put a soft kit in it with a book and some youtube...
If you wanted to get fancy you could do an AOD (no E).
If you're wanting a V8, a 351W (5.8L) and AOD are plentiful and not a major swap. You'll need small block engine perches, a modified drive shaft and have to tweak the tranny x/m. Mid-late 80s - early 90s F150s, Explorers, Broncos, etc are easy to find in the salvage yards and engine/trannies are everywhere. As a bonus, you can get them with serpentine belts and upgrade everything from the alternator to the p/s and AC.
Thanks for your help and suggestions guys....I think I’m leaning towards keeping the I6 and getting a C4 and sourcing out the column and such.
Stupid question...but what do you mean by “soft kit“...excuse my lack of knowledge
Thanks again!
Thanks again!
Not stupid, it is industry jargon....
A soft kit is the gaskets, bands, clutches and seals... those are considered “soft parts” where as drums the pump and gears are “hard parts”.
Example:
https://www.summitracing.com/ga/search/ ... uild%20kit
- jzjames
Take a gander at this video of the Ford inline six;Mitchell67f100 wrote:I think I’m leaning towards keeping the I6
https://www.youtube.com/watch?v=LaAPp3VPOdU
Thanks guys...awesome help!
I contacted a local guy about getting a C4 from him and he said for my setup that I should get a 1972 or newer to rebuild.
Does that sound right to you guys?
I would say in most cases always go with the newest.Mitchell67f100 wrote:Thanks guys...awesome help!
Information I have says they went to a push in modulator in 73, and changed to a C5 around 1980.
Prior to 70 there were differences in the way the valve body worked, primarily an absence of a second gear hold I believe (it would shift to 3rd if in 2), post 70 2nd was 2nd.
Make sure you know the input spline count (not sure when this changed, might be what your trans shop means) and get the correct bellhousing for your 300.
Thanks again!
That’s a great help....can’t wait to source one out and start work!
