double groove water pump pulley
rhyne
Post by rhyne »
I cant find a clear cut answer anywhere can anyone point me in the right direction. i want to put power steering on my 352 fe, and my only solution i can see is to run the belt to it from water pump. this was originally all manual so 1 belt from crank to alt to water pump. i have a 3 groove crank pulley now, but lower radiator hose is in the way to go from the to power steering. is there a 2 groove water pump pulley that will work for this? i have found several on ebay but unsure if depth width diameter will all work right.
thanks
rhyne
Re: double groove water pump pulley
Post by rhyne »
think i found it c6ae8509e
