AC's 70 F250
- AlleyCat
AC's 70 F250
Bought a 70 F50 on a whim last March. Figured I could get it up and road legal fairly quickly. You know that old line about the best laid plans ? Yeah it happened again. Anyway I'm finally caught up enough to get moving with it. Truck came from Cali so rust isn't an issue but it has lots of others to keep me busy.
While the truck drives straight and handles fine the frame horns ahead of the front crossmember are a mess. I considered swapping everything over on to another frame but canned that idea pretty quickly. My solution is to cut off the damaged sections and graft a pair of horns I cut off of a dentside at the local parts yard. The front sheet metal is shifted roughly an inch to the left. The game plan is to get the sheet metal back where it belongs then use it to help square to replacement frame horns. I'll post updates as it moves on.
I knew when I looked at it that it had been in a front end collision at some point at the front sheet metal wasn't quite right. I just didn't at first realize how far out of kilter it was. At this point I'll suggest that you never look at a vehicle, especially one that is white in color, in a snow coated lot on a sunny day. While the truck drives straight and handles fine the frame horns ahead of the front crossmember are a mess. I considered swapping everything over on to another frame but canned that idea pretty quickly. My solution is to cut off the damaged sections and graft a pair of horns I cut off of a dentside at the local parts yard. The front sheet metal is shifted roughly an inch to the left. The game plan is to get the sheet metal back where it belongs then use it to help square to replacement frame horns. I'll post updates as it moves on.
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
- 67mann
Re: AC's 70 F250
"California truck" in PA Looks like a nice (clean) project. Hope all is well, good to see ya kickin around
- AlleyCat
Re: AC's 70 F250
Got the outer front sheet metal and began to realize what a hack job somebody did to repair it.
Cowl on the left side had been driven backward. Some quality time with a come along got it pulled back into place.
Core support and both inner fenders are twisted. Pic above shows where the core support was heated and hammered in an effort to straighten it.Cowl on the left side had been driven backward. Some quality time with a come along got it pulled back into place.
Clay
- AlleyCat
Re: AC's 70 F250
Starting reassemble the front end with good panels.
At this point I'm not concerned with paint and small parts. The idea here is to align the front sheet metal with the cab and doors. Then I can use the core support to help square the new frame horns.
Clay
- hfdco4
Re: AC's 70 F250
Wow, that is a lot of work. I would still think about the frame swap.
FE390PC
FE390PC
- AlleyCat
Re: AC's 70 F250
I am watching for a parts truck with a good frame. Right now, with the other projects I have to do, a small dump truck would come in real handy. Since it has a 7500 lb GVW I can install an in bed dump unit and have enough weight capacity to stay legal.................Mostlyhfdco4 wrote:Wow, that is a lot of work. I would still think about the frame swap.
Clay
- AlleyCat
Re: AC's 70 F250
Lots of things going on but I've managed to make some progress.
Got the sheet metal on then came the fun part. Getting everything aligned. First I got the truck level. Then made sure the cab and bed were square and level with each other. Took readings on the door sills, rear window sill and the bed floor to verify this. Then I squared the fenders to the cowl and doors then leveled the rad support with the rear window sill. Lastly I reinstalled the rad, a shroud ( it was missing ), and the fan I plan to use. Truck came with a flex fan and I don't care for them. Had a clutch fan from an FE powered, a/c equipped dent side and on it went. While the vertical clearance for the fan was okay I had to pull the rad support to the right with a ratchet strap to get proper clearance for the fan.
After some torch work, 3 cut off wheels, 2 grind stones, many test fits the new horns are ready for welding.
Clay
- AlleyCat
Re: AC's 70 F250
I was taught many years ago to preheat frame rails before welding. While I didn't have a regular heating torch available I've found an ancient AirCo cutting torch with a #6 tip makes a pretty fair substitute.
Both sides tacked, rechecked for alignment and ready for final welding.
Got the right side welded in. When I began welding the left side the welder began having issues. After grinding out 3 crappy welds I called it a day.
Clay
- hfdco4
Re: AC's 70 F250
Awesome work and great detail. You will have a truck that will work very well for you.
FE390PC
FE390PC
- AlleyCat
Re: AC's 70 F250
Got the welder straightened out and the frame welding is done. After rechecking everything one last time I pulled all the front sheet metal back off. The inner fenders I had gone over for another project but never used them. The rad support came from a 78 F100 so it got the needed holes drilled for use in a bump. Also the bolt holes for the headlight brackets and dent hood latch were capped over and brazed shut. Still have to cut the hole for the a/c lines then scuff and primer it. Hoping to paint the support, inner fenders and a few small parts this coming weekend. While sheet metal is off there are several other issues I'm going to address. No pics this time, my camera took a dump. I'll be back on track for next time.
Clay
- hfdco4
Re: AC's 70 F250
Great progress man. Keep up the pace man.
FE390PC
FE390PC
- AlleyCat
Re: AC's 70 F250
Made a little more progress on this one. Inner fenders and the core support are ready for paint. Working on cleaning up the cowl. While the sheet metal is off I'm also fixing some other issues. Left exhaust manifold was leaking so I figured it would be a good idea to reseal them both. Much to my surprise the bolts, with a little heat, all came out. The engine has been apart sometime in the not too distant past While it runs strong all I can do is hope who ever rebuilt it did a better job on the internals than they did on the installation. Still having camera issues but I hope to have more pics soon.
Clay
- AlleyCat
Re: AC's 70 F250
Seam sealer on the cowl was brittle and in places flaking off. I used a spot blaster to clean the seams. Tomorrow it will get the seams resealed.
Clay
- AlleyCat
Re: AC's 70 F250
Radiator support and inner fenders are getting scuffed up and ready for paint.
Clay
Re: AC's 70 F250
Great progress!
