1969 F250 Drum brakes
Hello,
I have a 1969 F250 360 FE 2wd drum brakes all the way around. I am have a lot of trouble with the front drum brakes. The guy I brought the truck from completely messed up the front. I have all the parts to do the front drum brakes but I have no reference because the guy messed up both sides on the front. Does anyone have pictures? or I can take pictures if someone would like to correct whats in my picture. Thank you!
Re: 1969 F250 Drum brakes
If you go to the Technical Articles section at the top of the page where you find the Discussion Forum you are on. You will find in the upper left corner under Home a place where you can click on Diagrams & Schematics. Click on this, then click on Section B (Brake Assembles and Components). The 4th one down is the diagram Front & Rear Brakes- Self Adjusting-Typical. Click on the diagram and it will enlarge. Maybe some one can post this for you.
Good Luck!
Good Luck!
Here's the diagram. http://www.fordification.com/tech/image ... ont_01.jpg And here's a couple of photos of my rear brakes for a visual. Front and rear are pretty close to being identical. Remember, long shoe always goes to the rear.
Here is what I have so far you guys.. the self adjuster clip thing in my hand doesn’t stay on the shoe.. the brakes are 12 x 2.5.
- 1972hiboy
That wire anchor goes into the shoe and then you bend the tab over to secure it to the brake shoe.
Rich
Dont eat yellow snow.....
I feel so stupid right now.. you guys rock! My wheel cylinder is new but for some reason when I press on the brakes only 1 shoe moves?? Why is that?1972hiboy wrote:That wire anchor goes into the shoe and then you bend the tab over to secure it to the brake shoe.
- 1972hiboy
Be VERY careful applying the brake pedal with no drum installed, you can blow those wheel cylinders out, then you will have a mess. One plunger in the wheel cylinder can have less resistance than the other so it will move first. but typically once that side moves a bit the other will catch up. as long as both sides move by hand in and out you should be ok.Fordinblue20 wrote:I feel so stupid right now.. you guys rock! My wheel cylinder is new but for some reason when I press on the brakes only 1 shoe moves?? Why is that?1972hiboy wrote:That wire anchor goes into the shoe and then you bend the tab over to secure it to the brake shoe.
Rich
Sounds Great! I appreciate the help.. I will have an update tomorrow!1972hiboy wrote:Be VERY careful applying the brake pedal with no drum installed, you can blow those wheel cylinders out, then you will have a mess. One plunger in the wheel cylinder can have less resistance than the other so it will move first. but typically once that side moves a bit the other will catch up. as long as both sides move by hand in and out you should be ok.Fordinblue20 wrote:I feel so stupid right now.. you guys rock! My wheel cylinder is new but for some reason when I press on the brakes only 1 shoe moves?? Why is that?1972hiboy wrote:That wire anchor goes into the shoe and then you bend the tab over to secure it to the brake shoe.
Didn't realize there was such a big difference between F100 anf F250 brakes. Robroy did a great write up on his rear brakes. Except for the E-brake hardware, they're very similar. http://www.fordification.com/forum/view ... hp?t=49962. You can get a new hardware kit at your local parts store. https://www.oreillyauto.com/detail/b/br ... ware&pos=2
Do you have any idea how to separate the drum from the hub without a press?? I just purchased 2 front drums and didn’t realize that I need a hydraulic press to separate the hub from the drum.sargentrs wrote:Didn't realize there was such a big difference between F100 anf F250 brakes. Robroy did a great write up on his rear brakes. Except for the E-brake hardware, they're very similar. http://www.fordification.com/forum/view ... hp?t=49962. You can get a new hardware kit at your local parts store. https://www.oreillyauto.com/detail/b/br ... ware&pos=2
I've used a 50 ton press and have actually shattered the old drum pressing it off. I would press out the studs first as they are mostly responsible for holding the drum onto the hub.
1967 F-100 4x4 custom cab.
Will I have to purchase new studs? I was hoping I could reuse the original ones. I will have to call a few shops tomorrow to see if anyone one has a press.Busboy wrote:I've used a 50 ton press and have actually shattered the old drum pressing it off. I would press out the studs first as they are mostly responsible for holding the drum onto the hub.
- 1972hiboy
Fordinblue20 wrote:Will I have to purchase new studs? I was hoping I could reuse the original ones. I will have to call a few shops tomorrow to see if anyone one has a press.Busboy wrote:I've used a 50 ton press and have actually shattered the old drum pressing it off. I would press out the studs first as they are mostly responsible for holding the drum onto the hub.
I have used a brass hammer or brass punch before to pop those studs out one at a time. brass takes a beating but the studs usually survive.
Rich
I’m going to try the brass hammer! Hopefully that works.. I found a machine shop that may do it. He said he needs to see the drum and hub first. Thanks to you guys! I got everything back together I just need to order a new drum and do the passenger side.1972hiboy wrote:Fordinblue20 wrote:Will I have to purchase new studs? I was hoping I could reuse the original ones. I will have to call a few shops tomorrow to see if anyone one has a press.Busboy wrote:I've used a 50 ton press and have actually shattered the old drum pressing it off. I would press out the studs first as they are mostly responsible for holding the drum onto the hub.
Yeah the studs are reusable. They are swedged in at the factory to hold the drum onto the hub.
