Hey everyone
I’m in the middle of installing a Sterling 10.25 in the rear of my 68 F250 4x4 with a 4 inch Skyjacker Lift and I would like to know if anyone could give me a picture of the shock mounts with a few dimensions, on the axle tube of their factory Dana 60. I need this info to locate the new shock mounts on the 10.25. See, when I purchased my truck it had a Full Float D70 in it with the shock mounts below the axle U-bolt bottom plate like a 2WD F350 so I don’t have a D60 to reference for my new mounts. The 10.25 is under the truck now and spring pads located, not welded as I need to set the pinion angle but I would like to mark where the shock mounts go. By the way Skyjacker says their shock M9558 with an extended length of 24.84 and a collapsed length of 14.82 will work on a 0 to 4" lifted truck, I even called them to verify this. Any help would be helpful.
Also posted on Ford Truck Enthusiast
CStoyer
67-72 Dana 60 Rear Axle - Full Float Info Needed
- cstoyer
68 F250 4x4
Re: 67-72 Dana 60 Rear Axle - Full Float Info Needed
I did a '89ish 10.25 and it was a bolt in on my '70 F-350. You really need to find one with the correct spring perch width. The universal is a larger size so expect some drive shaft issues. I went 10.25 to get away from the 4.11 gear.
- cstoyer
Ranchero50
Thanks for the reply. My Sterling 10.25 is the later version, longer pinion, and I have a 1350 yoke for it. The NP205 transfer case I have in the truck I changed to a the 1350 output yoke as well to match, that I got from Tom Woods. The only thing left is the drive shaft when I get everything set Ill need to order with matching 1350's at both ends. I couldnt locate a DRW 10.25 with 40.25 pad spacing so I got SRW 10.25 with the same WMS of 66.5 but had to cut the pads and put new 2.25 inch ones on the tube at the correct spacing.
CStoyer
CStoyer
68 F250 4x4
