Front wheel hub
Front wheel hub
Here I am again guys with a problem only you can solve! Happy Holidays! The wheel fell off the left front of my 67 F100. Mechanic says he can't find a new one. Anyone know a source! Can you get new ones? Is the hub the same on more than one year. This the bottom-of-the-line one-half ton, straight 6. A relative answered the question with, "Good luck.... ." That's never good.You guys saved me beau coup bucks with a carburetor float, so I'm counting on you again. Many thanks.
Re: Front wheel hub
I've got one if you need it and can't find one locally. I can p.m. you a price if you can send me your zip code for a shipping quote.
1967 F-100 4x4 custom cab.
Re: Front wheel hub
2wd or 4wd?
Re: Front wheel hub
Got two I pulled off my truck for a disc brake upgrade, but they are for a 4wd. Sorry I couldn't help.
If you have no luck finding a good used spindle, might consider upgrading to disc brakes from a later model 2wd. Just a thought.
Re: Front wheel hub
I private messaged you. Not sure if you got it cause it showed to still be in my outbox for some reason.
