Right rear bearing
70xlt
Right rear bearing
Post by 70xlt »
I’m having slight friction/grinding sound on the right rear wheel area. there is no smell or leakage on wheel. Would this be the wheel bearing ? There is oil in rear end, etc. also can I pull the axle out without removing the hogs head. Any advice be greatly appreciated.
1972hiboy
Re: Right rear bearing
Post by 1972hiboy »
70xlt wrote:I’m having slight friction/grinding sound on the right rear wheel area. there is no smell or leakage on wheel. Would this be the wheel bearing ? There is oil in rear end, etc. also can I pull the axle out without removing the hogs head. Any advice be greatly appreciated.
f100? f250?
Rich
Dont eat yellow snow.....
70xlt
Post by 70xlt »
F100, did frame off so rear end sat for 1.5 yrs. got 800 miles on rebuilt 302 engine, auto. Purchased and then did rebuild so I never did much distance or speed on truck until now. Today since rear end cooled, right tire still hard to spin by hand and can hear in rear end turning noise, left side turns freely with little noise.
Thanks
bluef250
Post by bluef250 »
Pull the hub and check the brake assembly.
