I have never messed with this but I'm sure it needs to be checked. lots of dried oil and dirt on the box.
what kind of oil and how is it done? manual steering, thanks.....
67 f100 2wd steering box lube
Re: 67 f100 2wd steering box lube
Takes grease instead of oil....use moly graphite grease....there a port on top where you put it in......if I was home I'd show you exactly where.......
1997 Honda CBR 900RR
thank you
I will check it asap
