COIL SPRING HELP
Boydc1971
COIL SPRING HELP
Post by Boydc1971 »
I am in the process of my front drums to disc . I have a 1971 F100 and using donor parts from a 1978 F150. My question is if
I buy new coil springs which do I get them for ?
basketcase0302
Re: COIL SPRING HELP
Post by basketcase0302 »
="Boydc1971"I am in the process of my front drums to disc . I have a 1971 F100 and using donor parts from a 1978 F150. My question is if
I thought for sure it would say here which to use-but I did not see it?
Maybe re-read and someone else will chime in here that's don the swap.
http://www.fordification.com/tech/discbrakes01.htm
Boydc1971
Post by Boydc1971 »
I re-read the tech article on this swap. I didn't see a mention of what coil springs to use . maybe it don't matter .
I know that ride height does affect camber , so hopefully it will not be enough to adversely change it . thanks
