Pitman arm difference question
Ohiotinkerer
Post by Ohiotinkerer »
Been trying to find a C9TA-3590-E pitman arm and finally thought I had one located until I opened the box and discovered I had been sent a C9TA-3590-L. I called the p!ace I got it from and they are trying to tell me their cross reference says its the same thing and should fit so just out of curiosity I went out and froze my butt off to see if it would fit and it does go on my Saginaw box but doesn't seem to want to seat all the way up on the shaft - but I haven't cleaned and blasted it yet so not sure if its just because it has a little rust in the splines or if it just won't work. Can anyone give any specifics as to why it wouldn't work so I can better explain it to this guy since he insists it will? I quoted him EXACTLY what it says on the steering tech page but he still says it should work......... :?
1997 Honda CBR 900RR
Nitekruizer
Re: Pitman arm difference question
Post by Nitekruizer »
You would think that with the popularity of this swap/upgrade, that at least of the classic Ford places, LMC, Dennis Carpenter, NPD etc, would sell repop versions of the C9TA-E. Where did you buy it? Could you provide a link or a picture?
Ohiotinkerer
Nitekruizer wrote:You would think that with the popularity of this swap/upgrade, that at least of the classic Ford places, LMC, Dennis Carpenter, NPD etc, would sell repop versions of the C9TA-E. Where did you buy it? Could you provide a link or a picture?
:yt: .......that's exactly what I can't understand is why NOBODY repops them.....and I'm beginning to think they are as rare as hens teeth because I've been hunting for 2 months with no luck....... :(
I got it from a place called Chuck's Trucks LLC in CT - he deals with older F100 stuff but has connections over that way for newer stuff - only place I called that bothered to even call me back or return an email out of about a dozen places I tried......... Easiest way to see the differences is here.........
http://www.fordification.com/tech/str-s ... ations.htm
Ohiotinkerer
Gonna go off in a different direction........has anyone ever heated and bent a D2TA-3590-BA pitman arm to match the C9TA-3590-E? I have an extra one and have contemplated taking it to work and bending it to match the one I need since I can't seem to find the right one I need......I can t see where it would cause any problems as long as I get it hot enough and let it cool normally........ :?
crazyhorse
Post by crazyhorse »
Mr Tinkerer, good luck which ever way you decide to go.
Either way I hope you can find one that works.
:fr: :fr: :fr: :fr:
basketcase0302
Post by basketcase0302 »
It will take a lot...of heat to get the 1" thick forged Detroit steel, (back when steel was steel-not remelted Jap junk) steering arm hot enough to bend.
Try giving Jeff's a call:
https://broncograveyard.com/?gclid=Cj0K ... JqEALw_wcB
Ohiotinkerer
basketcase0302 wrote:It will take a lot...of heat to get the 1" thick forged Detroit steel, (back when steel was steel-not remelted Jap junk) steering arm hot enough to bend.
Thanks for the info on Jeff's - one place I hadn't tried yet........ :doh:
As far as bending it the place I work has about anything I need to just about anything so that shouldn't be a problem.........I think I'll head over to the weld dept at lunch and try it just to see if it can be done and post up some photos if it works.......... :D
Ohiotinkerer
Took advantage of the rare 70 degree day here to install the D2TZ-3590-BA pitman arm I heated and bent and thought I would post a photo of them together before I installed it......
I now have the correct angle and the drag link ball joint is centered instead of pulled toward the back of the socket......... :D
basketcase0302
Awesome deal. Wish I had a torch that big to bend it LOL. My small oxy/acetylene would never heat it enough? :lol:
Ohiotinkerer
basketcase0302 wrote:Awesome deal. Wish I had a torch that big to bend it LOL. My small oxy/acetylene would never heat it enough? :lol:
One of the advantages of working for a big company with a good boss who doesn't mind government jobs......... :wink:
That rosebud on the one of the torches back in welding could about melt it if I wanted to........ :evil:
