hi all,
I am looking at a 1970 F100 short wheelbase truck. It currently has a 302 which does not run and might be locked up. If I purchase the truck I would like to swap in a 360. Is there any difference in the suspension between a small block and big block truck?
Daniel
302 vs 360 suspension
Re: 302 vs 360 suspension
Other than springs and maybe wider front brakes I don't think so.
As far as I know, the brakes and suspension are the same regardless of engine size.
Fred
1970 F100 4WD short bed, 360 engine, very rusty plow and yard truck
1971 F100 2WD long bed, 302 engine, on the road
1968 F100 2WD long bed, 360 engine, stripping for parts
So the springs might be different? I know the fe engine is going to weigh about 200lb more than the 302. I know that old mustangs had different springs depending on whether the car had a 6cyl or a v8. Thought the trucks might be the same.
A '67 F100 will have 11" x 2" front drum brakes and 11" x 1-3/4" rear drum brakes. The '68-'72 F100s will have 11" x 3" front drums and 11" x 2-1/4" rear drums.
Steve
Thanks for the info guys!
