Neutral saftey switch & backup lights
indy358
Post by indy358 »
I am worried about installing a neutral saftey switch because the stem coming out of the steering colum is gone. Is this a replaceable item or do I have to buy a new steering colum to get the backup lights working?
Jayson
94 Cobra convertible Pace Car 300hp 302FI
07 Shelby GT 325hp 4.6L
58 Fairlane 292 Y-Block
65 Mustang 271hp 289
05 Excursion 4X4 XLT 6.0L
10 Camaro 1LT RS (wife's car)
76 Chevy Scottsdale 3/4 ton 4X4 350
qman
Post by qman »
Go here: http://www.dennis-carpenter.com/pdf/67-72_truck.pdf
It's on page 22 and is called a "A/T Neutral Safety Switch Selector Control Pin." It's $18 in this catalog but I think I bought one from the dealer for around $6 about 5 years ago.
72 F100 2wd 360 C6 Custom w/factory PS.
indy358
re: Neutral saftey switch & backup lights
Post by indy358 »
Thanks,
I found it through Carpenter. The Ford dealer still had the parts listed but it was $45
Jayson
qman
Post by qman »
What was it you needed exactly, just the selector pin or did you need the switch also? Because I think them switches are pricey.
acemang
Post by acemang »
I recently had the same problem, and friend of mine was knowledgable enough to know what years to find them in as well, so he saved me moola.
Ford-get about it
mrsnicks
Post by mrsnicks »
Thanks for the info on the broken post, I have the same problem. I got my neutral safety switch from autozone for either 29 or 39 dollars. Check autozone, advance if the other guys are too pricey.
Keep us posted what issues/problems you run into replacing that post. I'd love to avoid any headaches from someone else's experiences.
Thanks,
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
