Manny
Post by Manny »
hfdco4 wrote:Well as you know, these things have springs that do not bend very well at all...LOL.
They bend well with the weight of a tank on them :lol:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
hfdco4
Post by hfdco4 »
That is funny Manny! I received all the bearings for the front axle so I have stuff to do tomorrow.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Got a little done tonight in prep for tomorrow.
:fr: FE390PC
Manny
Post by Manny »
:drool: :pop: Your close to roller!!
hfdco4
Post by hfdco4 »
Got back at it today. Painted the knuckles. Got the top of the axle cleaned and painted. Installed the races in the cleaned hub.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Hub
:fr: FE390PC
Manny
Post by Manny »
What ratios you running here 4.10's. I don't know why but i love the axle work its just good fun. :D Also if you run into anything you need for that axle i have another one in the basement if you need anything for it let me know. :thup:
hfdco4
Post by hfdco4 »
Can you send me some pictures? I may need the shields, caliper brackets and calipers.
:fr: FE390PC
Manny
Post by Manny »
hfdco4 wrote:Can you send me some pictures? I may need the shields, caliper brackets and calipers.
WIll do i got the whole thing. Don't get your hopes up on the shields but i don't run them on alot of stuff. Both broncos and my brothers 350
hfdco4
Post by hfdco4 »
More done!
:fr: FE390PC
hfdco4
Post by hfdco4 »
Back at it again today. Finally got the lower ball joints to tighten, what a pain! Also got one Caliper Bracket cleaned and painted. Modified the brake dust shields I got at the swap meet earlier this year. Now I just have to tight the two top ball joint nuts and install the cotter pins. Did get the passenger side somewhat assembled.
:fr: FE390PC
Lone Ranger
Post by Lone Ranger »
Nice that axle looks new! I'm excited to see how you like your upgrade. :thup:
Kyle
hfdco4
Post by hfdco4 »
I think it will be a great upgrade. The disc brakes and parts availability are already big improvements.
:fr: FE390PC
Lone Ranger
Plus it's a heck of a lot easier to work on disc brakes and swap pads!
Kyle
hfdco4
Post by hfdco4 »
So true. I was able to get the other axle u-joint for Advance Auto at 25% off too. Don't think I will get to play with it till Friday though. I just want to get the axle back on the frame so it can be moved out and the cab can come back inside for that work over the winter.
:fr: FE390PC
