I performed the standard drum-to-disc conversion on my 67. I let too much time pass and don't know which hose goes on which side. I also don't remember how the hose runs from the caliper to the new longer bracket. I've checked the tech note.
A picture or four are worth a thousand words.
jck
If you also know about the washers required for the front-end rebuild, that would help.
Need a picture of brake hose routing
- jck_in_nc
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
- FORDification
- Site & Forum Admin
re: Need a picture of brake hose routing
Will these work?
I bent all new lines, so the steel lines coming up under the frame to the front brackets aren't exactly factory-looking...they would usually look more like this:
If you're using the earlier crossmember-mounted proportioning valve than the routing will differ a little.
Nice work, Keith. Where did you get the braided hoses?
- mrung0wa
Keith P. I'm surprised!
Haven't you heard of Stainless Steel Braided Brake Hoses R Us?
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- FORDification
Re: re: Need a picture of brake hose routing
I'm not using braided hose...just regular replacement lines. Didn't even cross my mind when I picked these up, but I've decided since then that I will go ahead and use braided for the flexible lines. Now would be the time to replace them, since I don't have any fluid in the system yet.Jake11 wrote:Nice work, Keith. Where did you get the braided hoses?
And I didn't want to use stainless steel for the hard lines since I wanted to bend them myself, for the experience. Stainless is so much harder than steel for a person to bend/flare that it's usually recommended a person buy pre-bent stainless lines rather than trying to do it himself.
- jck_in_nc
Great! Can I also get a picture of the hose going into the caliper? I don't know which is my right or left hose anymore.
Thanks in advance!
jck
Thanks in advance!
jck
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
I tried to find some a while back. Maybee someone on the forum
can have better luck.
I tried stainless steel brake hoses are us, but they put me on hold.
K.P
K.P
You did a nice job on the hard lines Keith, looks good!
- mrung0wa
Hey Keith P.!
FYI: I heard that their all out of stock on the Stainless Steel hose but they're overstocked on the copper and pot-metaled one's and are willing to make a deal on 'em!
Also since their roof leaked at the warehouse during the last rain storm they're clearing out their complete inventory of steel wool (you can buy it buy the pallet and save!!!).
Lawrence
Lawrence
