Dana 24 T-Case Question
4x4 & Off-road Forum Archives
Moderator: Doug Comer
skeeterg49
Post by skeeterg49 »
I have a '72 F250 4x4 with a NP435 and Dana 24 divorced case. I have never had any trouble with it slipping out of 2wd like I read about in some of the other posts but I have no 4-Hi, just 4-Lo. When I shift from 2wd into neutral it's smooth and then I can feel it go into 4-Hi but I still only have 2wd. When I push the shifter all the way forward, it engages 4-Lo just fine and stays in. I've taken it out in the field behind my house in the snow to "run" it a little and that is when I noticed it. Anyone got any ideas as to what I can do for it? 4-Lo and a Dana 60 rear with 4.10 gears doesn't give you much in the way of speed if you want to take it on the road. :D Thanks for the help in advance. Billy
1972 F-250 4X4
460ci @ .040 over w/MSD
NP435 Trans. Dana 24 T-Case
Edlebrock carb and intake
35x15.50x16.5 Super Swampers
:fr: and :fte: always has always will
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
is the front axle actually getting power in 4-lo? sounds kinda like the front hubs are not locked in to me. you would not feel the difference unless you needed the 4wd (in 4-hi) but you sure feel the difference when it goes into low range.
I use my truck all the time in low range with the front hubs unlocked, just for greater control of the torque.
heep70
Post by heep70 »
Try adjusting the shifter linkage. I believe you ajdusted it to make the linkage longer.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
skeeterg49
re: Dana 24 T-Case Question
To answer the first reply... everything works perfectly in 4Lo and all wheels will spin and or pull whichever the case may be at the time. I was looking at the shifter knob for the transfer case and it goes from top to bottom...
4Lo
N
2Hi
4Hi
Is this the correct knob for a Dana 24? If so, when the person I purchased the truck from installed the 460, it actually moved the case toward the back about 2 inches or so and I wouldn't be able to shift to 4Hi because it is hitting the back edge of the hole for the shifter. I guess I should look more closely and not post stupid questions. Thanks Billy
1972 F-250 4X4
heep70
Post by heep70 »
Yes, that is the correct sequence for the D24.
Why would everything get shifted 2" back? :hmm:
My 460 installation didn't require any repositioning of the tranny or the Tcase.
Greg
460 crew
Post by 460 crew »
I was curious about the movment also as I put the C6 in mine and it moved the tranny mounting spot back and I use a shorter driveshaft between the t-case and the x-case. With a manual it shouldn't have moved.
Sorry Greg I still haven't made it to the storage yet. :D
skeeterg49
That solves my problem for now. The only reason I can think is that the 460 came from a '77 Lincoln and not a truck so he fabricated motor mounts for it and it isn't exactly where it is supposed to be but I don't know for sure :hmm: . I haven't had much time to spend with the truck and have only had it for about one year. Over the summer I had to replace the turn signal switch and clean up the wiring in the rear and after I got that done I was just happy to be able to get her on the road some. Thanks for the help guys. Billy
1972 F-250 4X4
