Ford f100 1970 resto. Nearly done!
jurrien
Re: Ford f100 1970 resto after crash
Post by jurrien »
brake-, feul lines and brake stuff
all installed and some show off shots :woohoo: :D
[/img]http://i1180.photobucket.com/albums/x41 ... 4b8221.jpg[/img]
but... no limit wide ride sucks... more problems :cry:
how do i install my steering shaft?! only 1 inch room between the motor mount and rack
ive got it solved, but still, how does the design work like this?! :hmm:
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
67mann
Post by 67mann »
:hmm: what happened...Life get in the way :? This was the sweetest/fastest tear down rebuild...with some nice Mod's to boot...hope all is well
Craigerf100
Post by Craigerf100 »
Hey 67 mann, he's still posting progress. Just not here.
http://www.usatrucks.nl/forum/viewtopic ... &start=375
he's Dutch I think so he just hasn't been posting on our American website.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
67mann
Post by 67mann »
:thup: thanks for the info....guess I can still look at the pic's :doh:
jurrien
Post by jurrien »
67mann wrote::hmm: what happened...Life get in the way :? This was the sweetest/fastest tear down rebuild...with some nice Mod's to boot...hope all is well
i'm still building as fast as i can, but keep forgetting to post over here :roll:
Craigerf100 wrote:Hey 67 mann, he's still posting progress. Just not here.
i like it that you're following my topic at the dutch forum!
alright its going to be picture heavy again, this is what i have done so far since december :D
ordered a lot of parts, almost finished the steering pump mounting brackets.
got a new filler hole for the mustang tank, 2/3 of the parts that i have ordered are at the truck, still waiting for my shipment from NY (flasback f100's)
disassembled the steering, because the new pump wouldn't fit on the steering shaft
some one has been busy with the column :?
new brackets, the origineal place from the no limit wide ride wouldn't work, so i had to think of something else
fits perfect, but i have to change it, its probably not heavy enough...
rust was showing itself at the cab floor again, so it was time for some paint!
and then i started with the fuel tunnel
so i have to finish up the steering column, with a new bushing or ballbearing.
i changed the leafs in the right way, thanks trickf100!
last week i picked up some parts that were shipped to holland, started installing them just for show :woohoo:
:D :D
as you see, she smiles again!
i'm still expecting:
inner fenders
LH outer fender
new gauges
hood
cab to fender mountings
dash defrosters
this will probably arrive in about 4/5 weeks!
edit: almost forgot, i have designed an alu plate for the new alu radiator for a SPAL fan:
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Craigerf100
Looks great jurrien! And your English Is very good. Is it common there for people to know English so well? Just curious. :P
Blijf op het grote werk :thup:
jurrien
Post by jurrien »
Craigerf100 wrote:Looks great jurrien! And your English Is very good. Is it common there for people to know English so well? Just curious. :P
Thanks!
A lot of people speak English, i work offshore and not in holland, so i have to speak proper english.
but if you go to holland, most people (about 80%) especially the students will manage to answer your questions without a problem, it will sound funny with a dutch accent :lol:
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Fordnatic
Post by Fordnatic »
Nice work. Iike your gas filler setup, better than the cap on the floor of the bed like most seem to use. You probably will have to add a vent line to avoid gurgling and slow filling.
55F100
jurrien
Post by jurrien »
It was hard to get it over there, not perfect either but it will do.
I'll try to get an air vent on the original hole.
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Great work!
jurrien
Re: Ford f100 1970 resto after crash update:26/12/14 PHOTO heavy
Post by jurrien »
whow i should update more often over here!
it's going to be photo heavy again :thup:
Got all the second hand parts in months ago
see if it all fits
inner fenders didn't fit over the new wide ride
more paint
more work
sandblasted and first layer of paint
be gone paint! :evil:
Radiator shroud
bushing for steering column
fresh air
more paint
building up
Time to make a new wiring harnass
it's going pretty well :D
that's it for now, next week i will drill one more hole in the bed and after the bed, doors and some small stuff are going to the sandblaster.
i probably have some welding work to do after it and hope to bring it around februari/march to the painter :woohoo:
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Great job, Jurrien! You're doing some amazing work!
Mancar1
Re: Ford f100 1970 resto after crash update 26/12 picture's
Post by Mancar1 »
Enjoyed checking your project out. Very nice work. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
jurrien
Post by jurrien »
thanks guys, not much news at the moment, i am waiting for a few parts to come oversees.
The bed and doors are sandblasted and are getting a primer right now.
If i get back from work (mexico) i start with customizing the dashboard and then i'll start working on the bed :thup:
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
jurrien
Re: Ford f100 1970 resto, getting closer!
Post by jurrien »
Guys i need some help, I have no idea how to change these out.
I bought a new set at LMC, but there is no manual with it. Does anyone now how to do it?!
EDIT: figured it out!
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
