how to fill a jack with oil?
427
Post by 427 »
I have a cherry picker that the oil has leaked out of. What kind of oil and how do you refill it? I don,t know if you extend the jack or leave it compressed? Thanks for any help.Brian.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
Re: how to fill a jack with oil?
Post by cep62 »
Leave it compressed and use hydraulic jack oil or auto trans fluid.
there should be a plug on the side , about a 1/3 of the way up.
427
Post by 427 »
Is the plug possibly rubber and pulls out?
95 Ford Lightning
38 John Deere G
flyboy2610
Post by flyboy2610 »
That's the one. Fill it until you can feel the oil even with the hole.
Red Green
you'd better be right.
careful not to tear that rubber plug. its heck trying to find another one.
427
Post by 427 »
Hey guys thanks for all the help. :thup: Just wasnt sure what I was looking for.Thanks,Brian.
95 Ford Lightning
38 John Deere G
Whateverman
Post by Whateverman »
cep62 wrote:Leave it compressed and use hydraulic jack oil or auto trans fluid.
:2cents: I wouldn't recommend trans fluid,but only because using some Dexron i had laying around to fill (an already leaky) rental unit i was using years ago caused a critical meltdown before the weekend was over....
probably be safe if you stuck to Type F
Donnie
Post by Donnie »
Don't skimp here, go to any parts store & get a qt of jack oel...Donnie :woohoo:
