A good afternoon in the shop (big pics)
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Since it was a slow day at work and I was basically caught up, I took the afternoon off the spent it at the shop getting my truck's firewall cleaned up and ready for the POR-15. (That's on the agenda for tomorrow.) Took me about 5 hours altogether.
I did most of this with a wire wheel in the angle grinder, then I spent about 1-1/2 hours hitting all the areas that the wire wheel wouldn't reach with 60-grit sandpaper, then roughed up the entire firewall with it for better adhesion. The second picture was taken when I was 95% done....still had a few small areas to hit with the sandpaper.
By this time tomorrow the firewall should be completely done! :D
67fastbackFE
re: A good afternoon in the shop (big pics)
Post by 67fastbackFE »
Looks great Keith, keep up the good progress.
Tom
1972 F100 shortbed 360/C6
dcbullet
Post by dcbullet »
I love the sight and smell of fresh metal.
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
man thats going to be too nice to drive!
460 crew
Post by 460 crew »
Looks very good Keith,are you going to paint inside the cab mounts? :clap:
FORDification
Site & Forum Admin
Site & Forum Admin
Absolutely! I'm just waiting until the front end is completely mocked up so that I can tighten the cab down before coating the areas inside the cab mounts. Once those are done, I intend to completely seal up the cab mounts, drill a small hole down into them from the interior floorpan and then completely fill the mounts with cavity wax....so I'll never have to worry about them rusting out again!
