I want to do a hood flip on my 68 truck. The thing is I dont want the hood to just pivot but raise up and out in front of the nose kinda like a car trunk lid does. So what I was thinking was to get some car trunk lid hinges, the latching mechanism, and some gas struts and go from there. What do you guys think, any suggestions??? Thanx,
Don
Hood Flip
- GreaseMonkey
Hood Flip
1968 Ford F-250 "Puck" / 360ci V8 / C6 / Dana 60 Rear Axle (Resting in the "Big Pasture in the Sky")
1976 Ford F-250 Hi-Boy "Bubba" / 360ci FE V8 / 4spd T-18 / NP205 / Dana 44/60 Axles
http://www.fordification.com/galleries/ ... ?album=633
http://www.fordification.com/galleries/ ... ?pos=-1498
- customcrewcab
re: Hood Flip
its been done heres a pic of one. i think it would be a pain to on anything under the hood thats in the front.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
- DuckRyder
re: Hood Flip
You might look at late 70's-early to mid 80's bmws. Most stuff from the factory that had a front opening hood also slides the hood forward.
- DuckRyder
re: Hood Flip
I think you are thinking of Buick LeSabre/ParkAve.
Like everything else on them, the hood hinges are usually broken.
re: Hood Flip
I just remember a guy I used to work with had some forgettable GM frontwheel drive car that the hood slid out and flipped forward. Maybe it was a Buick... they all looked the same to me!
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
re: Hood Flip
Not sure how they work exactly, but early 60's T-birds had front flip hoods. Maybe checkout a t-bird site, unless someone here knows how their hinges work.
- GT-Racer
Re: re: Hood Flip
yes It was the Buick Lesabre, My sister had one and it slid forward then tilted. specifically the 89-90 models for sure.Kraig wrote:I just remember a guy I used to work with had some forgettable GM frontwheel drive car that the hood slid out and flipped forward. Maybe it was a Buick... they all looked the same to me!
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- customcrewcab
re: Hood Flip
heres another pic of that red truck with the flip hood. if i remember right the truck was built in 1980 so its worked for a long time. looks like he might have three hings. one on each end and one in the middle.
- customcrewcab
re: Hood Flip
this is what i would do. get some 1" tube and use it to support your hood. then attach you hinges to that. then you know its suporting the whole hood instead of just one end. it should also make it strong and easier to open and close because the hood will have less flex. heres a pic on what i am talking about.
