Wiring trouble
Heavenlyfire
Post by Heavenlyfire »
First I would check all the connectors on your altenator and then your starter cylanoid. If any of these are corroded real bad they will act up. It really sounds like the altenator itself has had it, but check those connectors out first.
hardtailjohn
re: Wiring trouble
Post by hardtailjohn »
I'd check connections, starting with ground connections, and at the same time look for any place it could be shorting.... from things jumping around and the lights going dim, I'd be very suspicious of an intermittent short somewhere.
John H.
flyboy2610
re: Wiring trouble
Post by flyboy2610 »
BTW, welcome to the forums! :D
Red Green
you'd better be right.
