Bootleg aftermarket awesomeness! show us what you got.
Show us your rides or projects!
SteveC
Re: Bootleg aftermarket awesomeness! show us what you got.
Post by SteveC »
err hmm not really least it wasnt held with bailing wire lol
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
tybob81
Post by tybob81 »
The po was on to something with the "c clamp exhaust manifold repair kit" you can find that at auto zone in the "help" section! :lol:
wordforge
Post by wordforge »
Man, some of the different stuff that people have used to fix these problems is so out there. Perhaps, some stuff like this would have been in order during the time our bumps were under the care of their PO's.
http://kalecoauto.com/index.php?main_pa ... ucts_id=35
http://kalecoauto.com/index.php?main_pa ... ucts_id=30
http://kalecoauto.com/index.php?main_pa ... ducts_id=1
If you are going to tell someone the truth you had better make them laugh otherwise they'll kill you.
- George Bernard Shaw
flatblack
Post by flatblack »
im guilty of doing the c clamp exhaust thing, but on a volkswagon golf where they have these stupid little pressure springs. i cut them off and stuck on some c clamps, works really good on a little 4 banger.
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
FLATBEDFORD
Post by FLATBEDFORD »
wordforge wrote:Man, some of the different stuff that people have used to fix these problems is so out there. Perhaps, some stuff like this would have been in order during the time our bumps were under the care of their PO's.
That's some great stuff!
Steve
My Photo Gallery
wordforge
Post by wordforge »
thanks man, I found them when some kid asked if he was going to have to "rejet the carb on his fuel injection set up" on his RX-7
yeah, sometimes i feel bad.
72stepside
Post by 72stepside »
That is a homemade spark arrester / fuel atomizer under the carb spacer. And yes, you guessed it.... made entirely of wire window screen. Where did all of it go you may ask... who knows? I'm sure I'll find out when I tear the engine down. But, to the P.O.'s credit, it was doubled up and had silicone around the edges for a tight fit.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
flatblack
Post by flatblack »
72stepside wrote:That is a homemade spark arrester / fuel atomizer under the carb spacer. And yes, you guessed it.... made entirely of wire window screen. Where did all of it go you may ask... who knows? I'm sure I'll find out when I tear the engine down. But, to the P.O.'s credit, it was doubled up and had silicone around the edges for a tight fit.
oh thats brutle, ive made my own spacers but why would you put a screen on it?
wordforge
Post by wordforge »
sorta looks like the stuff that Dyer's puts on their blowers
ezernut9mm
Post by ezernut9mm »
this is my 71 parts truck.
someone down the line must've swapped 4speeds and the shifter didn't bend right, so they made it bend right:
the front turn signals are "grote" trailer side marker lights mouunted with angle iron:
you can't see it too good in this pic, but that is a new replacement inner fender which was immediately cut up to route ac lines and power steering lines through:
and finally, the whole truck is "painted" with some of that do it yourself bed liner:
1971ford
Post by 1971ford »
ill go ahead and add this for Fordman :lol:
Stole the pic from Fordman's how not to do it thread in the drivetrain section
-Ryan
olgreen69
Post by olgreen69 »
there is absolutely nothing wrong with the C-clamp, this one has been holding strong for well over a year now
when i bought the truck the p/o also did the bungee cord thing so i fabbed this out of some scrap aluminum around the shop.
and my ultra high tech radio install using pipe strap to mount to the top of the glove box this way i don't have to murder the stock radio mounts.
and finally a good use for all those holes under the dash pad.
FordTruck
Post by FordTruck »
olgreen69 wrote: and finally a good use for all those holes under the dash pad.
That's the same place I put my CB for now soon its gonna hang from the roof like a big rig :D Is that a Galaxy radio??
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
SteveC
Post by SteveC »
this was on one of the other students trucks he owns... its the best exhuast hanger ever
1967 f-100 4x4
1971ford
Post by 1971ford »
for a second i thought that was a super crazy driveshaft support :eek:
-Ryan
