need pics of F250 leaf 4x4 front
zakt
Post by zakt »
want to get some pics of a F250 leaf front 4x4 set up... debating on getting front stock hangers to bolt on my 2wd F350 to convert to 4wd...
Thanx,
Todd
1972 Ford F350 crewcab
jtrojan715
Re: need pics of F250 leaf 4x4 front
Post by jtrojan715 »
might be able to help you out what exatly you looking for?
zakt
Post by zakt »
Im looking for a bunch of pics of the front leaf hangers (mounting locations), steering box location (steering shaft, pitman arm, tie rod, drag link etc) motor mounts, front cross member.
Thanx,
Todd
averagef250
Post by averagef250 »
Todd, not sure if it's still there, but there was a thread I started in the buildup section about switching a 78 F-350 crew to a 4x4 and installing a Cummins. There were a few good shots of how I made the engine stands and crossmember.
If you have access to a highboy frame I would splice the highboy frame into the crew 2wd frame under the cab. It would be far cleaner than making all your own frame parts.
Look at it like this- to convert the front of your frame to a highboy setup you are going to pull the whole drivetrain, completely remove every crossmember and bracket off the front frame rails and modify/build a ton of stuff to make it work. Way, way easier to just have the 2 frames side by side, do some real careful measuring, make 4 cuts and 2 nice welds where nobody will see them. Put the 2wd body back on with a 4x4 steering column and drop your engine in with a 4x4 tranny and mated t-case.
RedneckTexan
Post by RedneckTexan »
Good stuff to know! :thup: :thup:
Dustin, here's the link to the page yer talkin bout!
http://www.fordification.com/forum/view ... 22&t=27064
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
