Ran my truck out of gas!
mrtleavitt
Post by mrtleavitt »
I wanted to see how low my gas guage would go so I would know exactly how far was empty. I put a 2 gallon gas can in back so when it happened I would be prepared. Well, it happened yesterday and it wasn't as easy as I thought it would be. I put the 2 gallons in and I could not get it to start. I pulled the gas line before the pump and there was no flow. So I used a pump to get the gas flow going and then hooked it back up. Still no luck. I had to spray starting fluid in the carb and after it ran off the fluid, then the gas flow finally made it back to the carb. I thought our stock fuel pumps would pull the gas from the tank even if the flow was broken? I know diesels you have to prime them if ran dry, but is that the case on our trucks?
mljjones67
Post by mljjones67 »
It takes a bit to get it to the carb and fill the fuel bowls. I use a squeeze bottle with fuel in it rather than starter fluid.
kaptnkaos
re: Ran my truck out of gas!
Post by kaptnkaos »
Hey mrtleavitt...
If you have enough gas in the tank and a good battery, a mechanical pump will eventually pull enough gas to fill the carb.
It is much easier to prime the carb with a little fuel...
mljjones67's idea with the squeeze bottle is really good...
KaptnKA 8) S
mrtleavitt
Well that's what I thought. I put about 5 gallons in after the 2 gallons wasn't doing anything and I cranked the engine for a long time and nothing happened. I guess I won't try that again. It sure hurt the ego as my classic was dead on the side of the road. :oops:
westernkansas
Post by westernkansas »
moment of silence and a tear
flyboy2610
Post by flyboy2610 »
westernkansas wrote:moment of silence and a tear
:cry:
Red Green
you'd better be right.
3406kris
Post by 3406kris »
How does the factory start them when they are new? Shirley they don't dump gas down the carb?
mljjones67
I bet you they did fill the bowl up and used a little down the carb.
