Windshield washer pump question???
kaptnkaos
Post by kaptnkaos »
Hey Guys,
Does anyone have a source for stock style windshield washer pumps?
I need to replace the pump in '68 CS and dont wanna mess with putting an after market style...
Thanks again,
KaptnKA 8) S
heep70
re: Windshield washer pump question???
Post by heep70 »
You can still get the pumps at an auto parts store. They are universal with other makes and models. I don't have the PN, but they are available. I just did mine not to long ago. Take yours out and bring it to them.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
wildcard
Post by wildcard »
FWIW Mine didn't work and I took it out, squirted it with a lubricant and hooked it back up and it's worked ever since.
kaptnkaos
Post by kaptnkaos »
Cool Heap70...
Thanks alot for that info... mine doesn't work at all...
Now that I got the intermittant wiper switch and am getting just about everything under the hood re-done I wanna replace that too.
Thanks again,
KaptnKA 8) S
67 F100 in Richmond
Post by 67 F100 in Richmond »
mine was taken out long time ago...
by someone? :cry: :cry:
1967 F-100 the engine has these numbers on it 040 020 020
dont know whats in it.. but i do know the previous owner converted to 4 speed on the floor... when i figure it all out i will let you know
Tim P.
Post by Tim P. »
NAPA they even have a decient warranty on it.
Ford Is The Mountain That The Rock fell Off Of.
72 F-250 Camper Special 390 Stroker 419 CID 420 HP Natural Asp 200 HP NOS C-6 Dana 60 4.10
96 F-150 XLT 4X4 5.8 Heavy Duty 4EOD
i think the original pumps for a 68 only washer bottle are available from the vendors. i didnt know they made a generic one for a 68 only type. i know they make a generic type for the 69 and up type.
kaptnkaos
Post by kaptnkaos »
Hey Fordman,
Yeah, that's what I was thinkin' too...
After doing some research, I found the orginal replacement Motorcraft ones at NPD for $24.95 (pn 17664-4) plus S&H... they also have non-Motorcraft ones (pn 17664-4A) for $14.95. They also have the bottles for about $27 (I'm not sure if the Motorcraft ones are $10 better or not.)
According to NPD those are for '68-'70, but they list the same part number for all '68-'96 except for the '95-'96 turbo diesels.
I'm gonna take mine in and see if the have one for a newer rig at the local C.R.A.P. store and see if they are the same...
KaptnKA 8) S
yea they are wrong. i have a few of those stashed for my truck the originals dont fit any thing other than the 68 bottles. the 68 pumps are an "L" shape pump as you know. the other newer year pumps are a cylinder type pump.
Tim P.
Post by Tim P. »
sorry i gave wrong info I was thinking it was the same as my 72 with the cylinder type.
heep70
Post by heep70 »
New things learned :thup:
Greg
l1k2gadd
Post by l1k2gadd »
I took a 1971-type water bottle with the internal later-model washer pump, cut a long section of the wire off of the parts truck in the wrecking yard (73-79 uses these bottles), cut a connector similar to the washer pump end plug on the '68 motor and made myself a plug-in conversion wire. I plugged the conversion wiring connector into the original plug in my '68's wiring harness, routed the wiring behind the bottle so you can't see the jumper conversion plug, I hung the '71 water bottle on my inner fender, filled the bottle up, and it works great!
The D1Tx part numbered water bottles are real easy to find in wrecking yards and it's easy to do the conversion. I know the water bottle looks different, but it's still a factory Ford part.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
kaptnkaos
Post by kaptnkaos »
Hey l1k2gadd,
That's a really good idea...
I'll probably do just that for my bus Olde Skool...
It doesn't have a washer at all.
I did find an orginal style MotorCraft one at NPD for $24
That was about the same as a generic pump at Cute Rate Auto Parts...
It should be here in the next day or so...
Thanks again for the idea...
KaptnKA 8) S
wildcard
Post by wildcard »
Speaking of Old School, I think I still have the foot pump style with everything except a bottle around here somewhere. I had thought about putting it in the 67 at one time before I got rid of it.
