67 Project Update 6/1/2023 (Multiple New Posts With Pictures)
JWW
Re: My 67 Project-Floor pan install 2/21/10
Post by JWW »
Thanks for the positive feedback guys.
basketcase0302 wrote:How quickly is the shipping from BOTP? I've never ordered from them before, just wondering...
If I remember correctly, I received my floor pans and cab mounts within a week.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
JWW
Re: My 67 Project-Cab Mounts 3/24/10
Post by JWW »
Well, I received some an exciting picture this evening. My cab mounts and cab support pieces are installed. :D
Also, I will be picking up a freshly sandblasted frame tomorrow. I will post some before and after pictures of that. :woohoo:
JWW
2004 F150 Crew Cab
stephen44
Post by stephen44 »
Looks Great - I am at the same point ...
What are your plans for the cab corners - you can get the outer ones but not the inner ones and they are not flat so not so easy to make up yourself with out a beader ?
Stephen
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
JWW
Post by JWW »
stephen44 wrote:Looks Great - I am at the same point ...
Stephen
Thanks!
I have the cab corners. They go on next. A friend is doing the welding work. He does a heck of a job.
JWW
2004 F150 Crew Cab
stephen44
Post by stephen44 »
i'm assuming you have the outer corners - but what about the inner corners - they are two different parts and you can't buy inner corners ? - the corners are a sandwich - outer and inner
- Stephen
thanks
Stephen
JWW
Post by JWW »
stephen44 wrote:i'm assuming you have the outer corners - but what about the inner corners - they are two different parts and you can't buy inner corners ? - the corners are a sandwich - outer and inner
- Stephen
I agree about the inner cab corner pieces. May look at fabricating something.
JWW
2004 F150 Crew Cab
trukcrazy
Post by trukcrazy »
Great job. It is good to see these projects coming back around. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
JWW
Post by JWW »
trukcrazy wrote:Great job. It is good to see these projects coming back around. :thup:
Thanks TC. I'm sticking with it, just have to save a little $$ at a time so that I can work on her.
My plan today is to apply "Chassis Saver" Imageto my freshly sand blasted frame. Will post pics after completion.
JWW
2004 F150 Crew Cab
JWW
Re: My 67 Project-Painted Frame 8/18
Post by JWW »
Well, I finally got my frame painted. I did three coats of the Chassis Saver. Then I applied two coats of low gloss paint from Tractory Supply. Here is the top coat I used:
Here is a pic of the sandblasted frame:
Here is a pic of the finished frame:
JWW
2004 F150 Crew Cab
Caseys71
Post by Caseys71 »
:thup:, Looks great man!
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
67mann
Post by 67mann »
8) :eek: Your catching up and eveythings lookin great :thup: How long ya been wearing the chassis saver :lol: that stuff doesn't come off for nothin :doh:
keep that frame covered if you take outside The UV's will dull that Chasssis saver :wink:
JWW
Post by JWW »
67mann wrote:8) :eek: Your catching up and eveythings lookin great :thup: How long ya been wearing the chassis saver :lol: that stuff doesn't come off for nothin :doh:
Thanks. Actually I went ahead and topcoated the chassis saver. I didn't want the black to become dull. As far as wearing the chassis saver, boy it takes a while to get it off. Thank goodness I only got a little on my arm and elbow. :lol:
JWW
2004 F150 Crew Cab
FormerMarine1981
Post by FormerMarine1981 »
Looks great man, Keep up the good work. If you still have the engine stands from the 75 frame you might be able to sell them, they looked like they were small block stands :thup:
stephen44
Post by stephen44 »
Nice ! :woohoo:
- Stephen
thanks
Stephen
67mann
Post by 67mann »
:hmm: Those little helpers got ya busy on other stuff :D :lol:
