#02 - Jan. 22, 2007
How's your Ford truck parts knowledge?
xxxtina63
re: #02 - Jan. 22, 2007
Post by xxxtina63 »
I was thinking it looked a lot like the clip that holds together the heater hoses running to the heater core? :?
Sharkdance
Post by Sharkdance »
Thanks chips68. I was sure that I am right. But..... Now Im second guessing myself.
I went back and re-read what Keith posted about the part.
He said its "on all bumpside and dentside trucks"
While Im sure I saw that exact clip holding the steel fuel line to the gas tank on my bump, the dentsides had the tanks under them. Not in the cab. So I dont know where (if at all) that clip would go on a dentside.
Sharkdance
70 F250 2WD 360/C6
chips68
Post by chips68 »
Well, like Sharkdance said a dent don't have the tank in the cab, However I removed a tank from a 72 two weeks ago and it had the clip holding the line to the tank and this one (maybe not orignal) did not have a rubber coating. But like I said who knows if thats factory installed
there is one on the tank fuel lines in the cab tank fuel line. the last two trucks i parted had them. it does have some sort of plastic type of coating on it.
hoss103
Post by hoss103 »
Cool, I'm a wiener!
That is what I think it is.If you are right hoss103,you have to share half your winnings with me!
How 'bout 60-40?
Carl
'69 F100- 302, 3-on-the-tree
'04 F-350 SRW PSD
71 LONG BED
Re: re: #02 - Jan. 22, 2007
Post by 71 LONG BED »
FORDification wrote:I also believe that any clamp that held wiring, brakeline or fuel line was either plastic or a metal clip dipped in liquid rubber...I don't think they used a straight metal clamp on those items, to minimize chafing.
Keith, I'm going to double check, but I'm almost certain that there were clips just like this one holding the steel fuel line on the frame under the motor. And also on the steel vent tube that runs on the other side to the charcoal canister. I'll check into it and let you know if I'm remembering correctly. :D
John Member #1549
Image Image Image
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
I know that the steel fuel line that runs along the frame is held onto the side of the frame by plastic clips, there are no steel clips along that at all. And fordman verified that the in-cab tank does use one of these clips on the line that runs down along the side of the tank, but the clip isn't plain steel, but lined with plastic. However, if you could check what holds the vent tube line that goes to the charcoal canister, that would be great. :thup:
kknip
Post by kknip »
hoss103 wrote:Cool, I'm a wiener!
How 'bout 60-40?
OK! :$$: :lol:
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
69F110
Post by 69F110 »
Dag-nabbit! I got here too late. I was going to say it's the clip that holds the doomahiggy to the cable attached to the whatchamacallit, thus preventing that thingy from flappin.
Steve Davis
Pastor and U.S. Army Retired
71 LONG BED
FORDification wrote:...if you could check what holds the vent tube line that goes to the charcoal canister, that would be great. :thup:
I was a little hung up last night, had to run out and pick up something for two-bit. :thup: I'll check tonight. I remember the clip from when I had the motor out. I hope I'm remembering correctly. I'm actually second guessing myself now. :hmm: :P
John Member #1549
Image Image Image
jeepermc
Post by jeepermc »
chips68 wrote:Well, like Sharkdance said a dent don't have the tank in the cab, However I removed a tank from a 72 two weeks ago and it had the clip holding the line to the tank and this one (maybe not orignal) did not have a rubber coating. But like I said who knows if thats factory installed
Holy old threads batman..... but my 75 dentside 4x4 has a in cab tank..... maybe itsa canadian thing?
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
yes the f 350 dentsides had in cab fuel tanks up to 75 or 76
FORDification
Site & Forum Admin
Site & Forum Admin
The F250 4x4s also had them, up through '77-1/2...since they still had the narrow frame spacing, an aft-axle fuel tank won't fit.
