Headlight conversion?
hillbilly67
Post by hillbilly67 »
I was wondering if anyone has changed over their headlights to the kind with the replaceable bulbs. I'm in Canada, and not sure where to look to find these things. I've seen some square types, but so far have been unable to find round ones. I replaced the originals with halogens and put in relays which helped a lot, but, with 16 hrs of darkness, along with blowing snow most of the time, I would like to change them to the blue lights. It's either that, or move somewhere with a better climate! hmmm...maybe I should look into that a lil closer.....it's starting to snow right now! Great! Only 8 more months of this.....
Big D's 69
Post by Big D's 69 »
I just ordered the lights and the harness from LMC trucks. I want be installing it any time soon so I can't give you any details on it. But it was less than a 100 bucks for the two lights and harness. Didn't buy the bulbs cause I'm going to buy some local.
hillbilly67
re: Headlight conversion?
Thank you Big D! I wasnt aware of LMC (stuck out here in the boonies and all) I just found my new favorite place to shop! Next truck I do may be ALL new parts. They have everything. Those headlites are exactly what I've been after, and sure cant complain about the price. Very much appreciated! The ol 67 is gonna be lit up brighter than the christmas tree.
Big D's 69
Re: re: Headlight conversion?
hillbilly67 wrote:Thank you Big D! I wasnt aware of LMC (stuck out here in the boonies and all) I just found my new favorite place to shop! Next truck I do may be ALL new parts. They have everything. Those headlites are exactly what I've been after, and sure cant complain about the price. Very much appreciated! The ol 67 is gonna be lit up brighter than the christmas tree.
Not a prblem glad I could offer some useful info for ya. Let me know how they work when you get them. If they work as good as they look then those things are gonna be awesome.
heep70
Post by heep70 »
Hella makes 7" conversion headlamps that fit in the buckets. In fact LMC sells them for like $50 ea. They use the replacable bulbs. Word of warning "DO NOT RUN A STRONGER WATTAGE BULB, IT WILL CRACK THE LENSE!" At least that is their answer to why mine cracked (thermal cracking). I know longer use the headlamps. I found the nighthawks are really bright. I also have put relays into mine. That really helped.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
zakt
Post by zakt »
I have some matrix 7" housings
1972 Ford F350 crewcab
Leadfoot
Post by Leadfoot »
bosch makes them to, and I found the seals/ bulb retainers to be much better than the competitions, and they plug right in to the stock plug, but they cost about $100 ta $125for a set . and are available at canadian tire, Napa, and all auto parts plus stores.
WHAT ?
Galaxie64
Post by Galaxie64 »
Good thread, I am planning on upgrading at some point. I already have half a room full of parts so I better hold off until I install some of what I have lol
'68 F150 2wd
'72 F250 2wd Camper Special (400/C6/4bbl)
'64 Galaxie 500 (3524bbl/57K miles)
'92 Grand Marquis (mostly stock 4.6L)
'97 F150 (heavily modded 5.4L)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
** Chuck Norris has counted to infinity -- twice. **
Clarko
Post by Clarko »
Make sure you DO NOT have a plastic lens, they suck! The glass lens is the way to go! I did it on my buddy's Mustang. Super easy.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
Big D's 69
I can't wait to see mine installed, but gonna be a while. But I have them in the box next to my desk that I just got today.
heep70
Post by heep70 »
Cool, you got a new desk today? Any pics? :D
Kiddin :P
Greg
