Trailer Wire Hookup Help
cghstrojan08
Post by cghstrojan08 »
What should I do to hookup a simple 4 point trailer hookup?
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
brown is brake tailwhite is ground or neutral yellow and green are the turn signals but i can't remember which side is which use butterflies to hook in the under bed wiring. they should be those colors also.
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
