Horn Assembly/Gear Indicator
erikhillard
Post by erikhillard »
Want to install a horn and the gear indicator in my truck. Neither were there when I bought it. I see the indicators listed in LMC and Dennis Carpenter. Is that the only item I need?
Also I see all the horn parts in the catalogs but I'm not exactly sure what I need and what is still in the truck..
Here's a pic.. Thanks in advance..
Best,
Erik H
1968 F100 Ranger
California
you need the brass spring button the horn spring and the horn button. and the plastic piece that sit on top of the column for the indidcator.
erikhillard
Thanks Fordman..
The horn bar is not needed?
You can use either the bar or a button?
Best,
Erik H
1968 F100 Ranger
California
its a center button with three tongs that go out to meet a half ring.
