STICKY: 3G Interchange Facts. Read if you're thinking 3G
- rjewkes
what about the volt reg? do you scrap it and wire to the newer plug?
I never had any battery problem with 208 watt stereo and my 100.2 amp amplifier. And extra marker lamps everything was brite except the cluster.
fuelly.com
fuelly.com
- Clarko
- turbocharged400sbc
re: 3G Interchange Facts. If you're thinking 3G, read here.
I just wanted to say thanks...this is one of the reasons i love this site...
I spent 1hr today before work looking in every one of our alternator boxes at my work (Autozone hanover park IL) and i think the one i found that i thought would work was that alternator right there...i'll check the part # when i get back to work tomarrow but it sure looks like the bugger...i guess i shoulda checked here first
wait! more's law dictates: two alternators are better than one....hmmm i like this theme...
james
james
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
- Clarko
Bump
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
Re: re: 3G Interchange Facts. If you're thinking 3G, read he
this should probably be stickied...my 1800watt power inverter loves the new alt over the stocker...Clarko wrote:Bump
though i now have a useless ammeter
- Clarko
- Manny
Note i tried today to hang one on my 67 camp spec with the low hung brackets and the alt hit the front crossmember since it was highboy which would fit that clarko.....
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- Clarko
Here's a good link to read with more info if you're contemplating this alternator swap:
http://www.network54.com/Forum/74182/thread/1176499765/
Here's another SIMPLE 3G wiring diagram:
http://www.bcbroncos.com/3ginstall.pdf
- cathynkeith
I have scrapped the regulator and have a 1 wire set up, gm style. Leaves the compartment clean and its simple.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- jbrown414
Anyone know which 3G would work for a inline 6?
I have a 91 sable. Just wondering what I need off it?? Just the alt. or some of the wiring too??
- Clarko
thanks clarko that helps
- Clarko
