1968 F250 Project
Re: 1968 F250 Project
Great work, keep it coming!
- pedro69ford
persistence truly is a main factor,evidently you lack none.GREAT WORK.Thanks for sharing.
- 1968-f250
sargentrs wrote:Great work, keep it coming!
Thanks guys! The encouragement definitely helps.pedro69ford wrote:persistence truly is a main factor,evidently you lack none.GREAT WORK.Thanks for sharing.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1957 Ford Fairlane 500 convertible (x2)
1979 Ford Bronco (x2)
1956 Ford Thunderbird
When the going gets tough, switch to power tools -Red Green
1964 F100 Short box
1968 F250
1972 F100 4x4
- hfdco4
Well your great work deserves all the encouragement you get. Keep it up and you will be driving it soon.
FE390PC
- 1968-f250
Thank you!hfdco4 wrote:Well your great work deserves all the encouragement you get. Keep it up and you will be driving it soon.
I currently have most of the engine work done, and it should be sitting in the truck by the weekend. I had pulled the oil pan a few days ago, and it was clean as a whistle inside. Amazingly most of the original paint was left on the engine because of the grease build up. Since I'm not making a show truck I am going to leave the original paint on the oil pan, but I will repaint the rocker covers and the air cleaner to freshen it up a bit. It has been 3 years since I last heard it run, and I can't wait to hear her run again. The front suspension is also in one piece again, and the truck is finally sitting on all 4 wheels again. I'll get some pictures posted soon!
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- pedro69ford
LOOKING FORWARD TO SEEING IT BACK ON ALL FOURS.
- 1968-f250
I'd love to get some pictures posted, but photobucket is being stupidpedro69ford wrote:LOOKING FORWARD TO SEEING IT BACK ON ALL FOURS.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- 1968-f250
Engine is In
The engine is officially in the truck!!!!
Time for pictures
Back on the ground
Rocker covers and water pump
Intake
Bell housing
Oil pan
heads on
Intake and rocker arms on
Drum roll please...
After three years the engine is finally back where it belongs. I'll need to buy another starter since the one I have is shot. We have been trying to fire it up for the past few days. Something must be wrong with the wiring since the dash lights do not turn on, and turning the key won't turn the engine over. We did bypass it by jumping the solenoid with a screw driver like usual, and then found out that the bendix in the starter is messed up. We'll eventually get all of the problems sorted out.
My dad also finished up the driver's side door a few weeks ago
In summer I will also be painting the rocker covers and the air cleaner. Wish I had more time
That's all for now.
Time for pictures
Back on the ground
Intake
Bell housing
Oil pan
heads on
Drum roll please...
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- 1968-f250
Hey guys! I was finally able to drive the truck!!!
I'm so stoked! We put the rusty front clip back on for now so it could be driven around, and it runs beautifully other than the fact that the carburetor needs to be rebuilt, and I already have the kit for it. It just felt so good to hop in and turn the key and listen to it fire up. I can't wait until I get my driver's license! Here are a few pictures of her...
As of now it sits with a little rake, but once the box is back on it should go back to normal. Not sure what to do front clip wise. I might end up going the dentside radiator support switch swap mine is even rusted up near the headlights. The passenger side inner fender is easily repairable, but the driver's side is completely gone, and the hood hinge is ready to fall off. I did pick up an inner fender for that side, so at least that is figured out. I'll probably end up buying new fenders for it. I'm just so excited that it is running and driving!
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- jimmy828
I bet if you had red lip stick on, you would have had red on both ear lobes smiling so much while driving that rig. Be glad when i can smile like that! Good job
- popeyes71
Good job!!!
Hard work does payoff! Another bumpside that will live on for a long time.
-Popeye-
1971 F-250 4x4 Highboy
- 1968-f250
jimmy828 wrote:I bet if you had red lip stick on, you would have had red on both ear lobes smiling so much while driving that rig. Be glad when i can smile like that! Good job
Thanks guys! This moment has definitely been a long time in the making. Now.. just need to find more partspopeyes71 wrote:Good job!!!Hard work does payoff! Another bumpside that will live on for a long time.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- flyboy2610
Congrats on getting the truck running!
Red Green
you'd better be right.
Red Green
- 1968-f250
Thank you!flyboy2610 wrote:Congrats on getting the truck running!![]()
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- pedro69ford
