Post your 4X4 pictures HERE!!
CO684X4
Re: Post your 4X4 pictures HERE!!
Post by CO684X4 »
Very Nice
ok68crewcab
Post by ok68crewcab »
motorheadjohn wrote:My toy....
Looks very nice! Is it a 68 or 69?
2 Blessed 2 Be Stressed
1971ford
Post by 1971ford »
its a '69 from the grill.
very nice!!
-Ryan
jeepermc
Post by jeepermc »
Tank wrote:
jeepermc wrote:Need more pics of it but don't have em...
Thats a cool looks spot to play at. Where is it?
Here's my new bump '72 F100
that's called "moon rocks"... It an area in Eastern Washington near "funny rocks"... In the manastash area near bald mountain outside of Ellensburg.
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
FLASH 1
Post by FLASH 1 »
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
Fordnatic
Post by Fordnatic »
FLASH 1 wrote:here is our back up truck
http://i512.photobucket.com/albums/t325 ... ge4042.jpg
Interesting dually fenders-I guess those are custom??
55F100
averagef250
Post by averagef250 »
Eeee Gads! Is that on a GM/Didge dually chassis? Sacriledge!
fomocoguy
Post by fomocoguy »
That truck is sweet! It deserves a good spit shine. As far as custom beds go for dually apps it looks great! :thup:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
montana_hiboy
Post by montana_hiboy »
That's one sweet looking rig!
Jim
'75 Ford Highboy 390 4spd
FLASH 1
Post by FLASH 1 »
Its sitting on original chassis with vin number still very visisble on top of frame rail before I bought it that was the first thing I checked since in NC it has to go through a DMV Inspection since being out of state so if its not right, state will not issue a title like all the other out of state trucks we bring in,,, It has divorce transfer case operated by a cable,,, dics on front has been done,, a awesome looking power steering gear box that at 70 on some of the back roads here can drive with one hand I will take a pic of that tomorrow it has column that at the bottom where the shaft is has a big shaft like a steering shaft off a semi to a gear box that sits on flat plate mounted to the outside of frame rail,,, the rear outside dually fenders look good but have not seen any on any other factory trucks,, It carries 75 gallons of gas that all fills up though the inside cab tank with a 3-way valve by drivers seat,, has a hidden goose neck hitch in the bed,in which he said he was pulling a horse trailer, not to keen on sunroof, does have a rear slider but yesterday cranked the a/c up on it, I been under it sevarl times and you can tell its a western truck with no cancer,, have to undercoat bottom of the bed still has red factory primer on it, anyway will take some pics of some key looks to look at...
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
montana_hiboy
What's up with the louvered hood?
Jim
fomocoguy
Post by fomocoguy »
FLASH 1 wrote: anyway will take some pics of some key looks to look at...
That would be great! What engine/trans combo does it have?
Joe
2005 Ford Ranger
FLASH 1
Post by FLASH 1 »
460 WITH C-6 Divorced transfer case,, those pieces on the hood I was told that where installed by a Movie Production Company to carry the weight of Movie Equipment, I know I can stand on the hood with no give
http://i512.photobucket.com/albums/t325 ... ge4061.jpg
this is the power steering gear box set up
Had to buy this tag at the Ford Dealership says MEET THE BEAST
http://i512.photobucket.com/albums/t325 ... ge4065.jpg
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
4x4freakfe427
Post by 4x4freakfe427 »
You guy got some real nice trucks out there. I will try to put up some pics of mine if I can figure it out.
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
71PA_Highboy
Post by 71PA_Highboy »
FLASH 1 wrote:Its sitting on original chassis with vin number still very visisble on top of frame rail before I bought it that was the first thing I checked since in NC it has to go through a DMV Inspection since being out of state so if its not right, state will not issue a title like all the other out of state trucks we bring in,,, It has divorce transfer case operated by a cable,,, dics on front has been done,, a awesome looking power steering gear box that at 70 on some of the back roads here can drive with one hand I will take a pic of that tomorrow it has column that at the bottom where the shaft is has a big shaft like a steering shaft off a semi to a gear box that sits on flat plate mounted to the outside of frame rail,,, the rear outside dually fenders look good but have not seen any on any other factory trucks,, It carries 75 gallons of gas that all fills up though the inside cab tank with a 3-way valve by drivers seat,, has a hidden goose neck hitch in the bed,in which he said he was pulling a horse trailer, not to keen on sunroof, does have a rear slider but yesterday cranked the a/c up on it, I been under it sevarl times and you can tell its a western truck with no cancer,, have to undercoat bottom of the bed still has red factory primer on it, anyway will take some pics of some key looks to look at...
There are some very odd things about this truck... Passengers side drop on the front axle, 4x4, dually, crew... Cable operated transfer case?
There is no way all this is stock... the VIN may be match the title, but please define original ...
I still like it... ;)
R/
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
