Post your 4X4 pictures HERE!!
- 1971ford
Re: Post your 4X4 pictures HERE!!
Almost done. It will be my DD in less than 2 weeks.
The #1 thing that I was surprised on when rebuilding the entire chassis was the t-case bushigns. You guys might want to check yours out, might be worth spending a day replacing them. The other bushings on the truck were in pretty good shape but the t-case bushings were done for. No one ever thinks of replacing them because you never see them.
-Ryan
- jeepermc
Nice work bud! All the work you have put into your trucks is priceless...Time spent with your dad too makes it all the more special!. Keep doing what you're doing!
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
1987 Mustang GT
- 1971ford
Thanksjeepermc wrote:Nice work bud! All the work you have put into your trucks is priceless...Time spent with your dad too makes it all the more special!. Keep doing what you're doing!
I've been doing all the highboy work myself, but my dad/brother help with the body lifting and dad helps work on the race truck.
-Ryan
- Art
My 1969 F250 4WD:
Its a scanned pic from 20 years ago. I still own the truck today, and currently it is about 95% done on a body-off-frame complete over-restoration after I rolled it over. Powered by a 440 Chrysler and 727 trans. 8' stepside bed is the original. Factory optional grille guard is from my dad's 1967 2WD F250 he ordered brand new.
I own three other 67-72 ford trucks, but they are all 2WD.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
- 1971ford
Your trucks was very nice look.............
- lifted72
Here's my 72, it has 71 grill inserts. Also a 351C, 7" of total lift.
POLISH EVERYTHING
That dash is incredible!! How did you make the eye brows in the top of the cluster? Metal work then re-chrome?
55F100
55F100
- lifted72
Hey thanks for the compliment. I used some old (believe it or not) metal tiki torches that were cones, and cut pieces of them to fit. Then I cut up the F600 dash and used a high tensile strength epoxy glue to hold it together. Once I finish smoothing it out I am going to paint it a metallic gray.
POLISH EVERYTHING
That is a nice, clean 72! What tires are you runnin? Thx
- jeepermc
Those are Toyo M/T's....look like about 35's?spartanpride wrote:That is a nice, clean 72! What tires are you runnin? Thx
- lifted72
They are 37x14.5-15'sspartanpride wrote:That is a nice, clean 72! What tires are you runnin? Thx
POLISH EVERYTHING
- grabberblue72
i have a pic of my dads truck in the photos section, but i thought id put some here too! body is mounted on a 85 f250 chassis with a 6.9 diesel.
and some more pics of my dads and a friend of a friends 72
Her's a pic of a truck we used to see around town:
