67 to 72 Bed patch
BayStYAt
Re: 67 to 72 Bed patch
Post by BayStYAt »
luke-ao wrote:Nothing that wide. I have this left over from sectioning a lb into a sb.
I'm swamped but when I have a chance I'll look crossly as to how much time it would take to remove the brace. The spot welds would need to be drilled out, are you OK with having to fill them? The material is in excellent shape so welding wont be an issue.
Hi
I need a 14"x 14" piece.
Blue_Streak
Post by Blue_Streak »
Yes, I'm ok with that. A small hole is much better than a big hole.
You don't happen to have a good fender support brace do you? You know the ones that go underneath between the bed floor and the underside of the fender. I have one that's mangled and would love to have a good one to replace it with.
luke-ao
Post by luke-ao »
Sorry I don't have any fender support braces.
