Replacing the king pins and suspension bushings
68F100Merlin
Re: Replacing the king pins and suspension bushings
Post by 68F100Merlin »
Just got out from under the 68 trying to find the source of the noise when I ease over speed bumps. Yup radius rod bushings went Tango Uniform. The first thing I do is come to Fordification and see is anybody has some tips I can use.
YOU ARE THE MAN!!
Thanks for taking the time and doing a great job with the pics.
:fr:
jimmy828
Post by jimmy828 »
just want to say thanks for the info and pics on the kingpin and bushing installment. I'm just getting started on a disc brake swap and replacing all bushings up front also. This post was very helpful. :thup:
flyboy2610
Post by flyboy2610 »
Thank you for the kind words. :)
I have been helped much by other peoples posts and pictures, so I'm just trying to "pay it forward."
Red Green
you'd better be right.
Dr Casti
Post by Dr Casti »
flyboy2610 congrat on a great post! the best i´ve ever seen so far.
Also, did you mentioned amazon to buy the bushings? What about the part no. can you post them?
Thanks a lot and my hat goes off to you, again.
1969 Ford F-250 Camper Special. 360 V8, C-4 auto.
JPC1972
Post by JPC1972 »
great post flyboy2610! would love to do this myself but its out of my league plus I don't have a place to stow my truck on jackstands while I wrestle with the 40+ years of old rubber and fused metal.. great job on your write up1
Jim
1972 F250 390 C6 "Rusty"
flyboy2610
Dr Casti wrote:flyboy2610 congrat on a great post! the best i´ve ever seen so far.
I'm sorry I missed this post! :oops: :oops:
The part number for the bushings are:
Prothane 6-604 Red Axle Pivot Bushing Kit with Twin I-Beam
Prothane 6-1207 Red Radius Arm Bushing Kit
Moog 8524B King Bolt Set
Red Green
Dr Casti
Post by Dr Casti »
Thank You! :thup:
SoCalExile
Post by SoCalExile »
About to do the brake swap. One thing I can't find though, is the rubber bushings that go between the coil and the radius arms and get secured by that bolt. Where did you get yours and what are they called?
marz68
Post by marz68 »
Nice work! I think you could have saved some money on those spring compressors. You don't need them for ibeam suspension. I've done my 89 ranger drop with out spring compressors, all you do is let the ibeam hang and start unbolting the spring.
jimmy828
Post by jimmy828 »
Flyboy,your post were helpful. Finally get my disc spindles back tomorrow from having new king pins reamed out. New coil springs,shocks,all bushings,tie rod,drag link. I hope front suspension goes in a heck of alot better than it came out!! What a ^%&)*# job that is to take all that out and sandblast and paint!
:yt: A royal pain! But it does go back together a lot easier. Hope you marked your i-beams for L/R. I didn't and had get the guys here to help me sort it out. Springs too.
jimmy828
Post by jimmy828 »
sargentrs wrote::yt: A royal pain! But it does go back together a lot easier. Hope you marked your i-beams for L/R. I didn't and had get the guys here to help me sort it out. Springs too.
I am using the bump stops on i- beams for reference . I am using Moog springs, they are the same height on both sides. I learn that they are different from factory. Since the bumps stop were mentioned, do i have to cut them off since i am using 74 spindles?
Probably so as the bump stop is incorporated in the spindle of the '74 disc. My '70's actually were already removed even though I had drum brakes. Just a hole where it used to be so I figure if the '74 spindle bump stop is insufficient I can always add a little more in the original location. However I think it's fine without it.
68FORDJBM
Post by 68FORDJBM »
Awesome post! Now I feel both confident and a little overwhelmed that I can redo my front end suspension. All I thought I had to do was replace the radius arm bushing :)
crazyhorse
Post by crazyhorse »
SSooo in order to install new king pins , I have to have some machine work done before installing the new king pins?
Can I not just remove the old king pins and put the new king pins in?
Thanks for a great thread.
