bumps with lowered altitude!! (lots of great custom bumps!!)
- turk54
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Just wanted to post a few pics with my new wheels, something for us longbed guys.
18" SVT Lightning wheels from a 99.
Unrestored 71 Bump, 4x2 LWB, 302, 3 speed on tree, 40,000 original miles
71 Torino 500 Halo, 302, Auto
- Joshpow
thats a nice look turk54. i like the longbed trucks too. nice.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- marvin2
turk54... the lighting wheels look great on your truck. I didn't think that '97 and up f150's had our same bolt pattern...are you running adapters?
- F100builder
Those look great turk!
...and marvin, I could be mistaken but I think the F150's had the same pattern through the '04 Heritage (early '04 and same body style as the '97). The late '04 (new body style) had the 6 lug on the F150 and I think some even had 7, yes, 7 lugs.
Patrick
- turk54
The bolt pattern is different, but if you drill out the holes to 11/16" it makes them large enought to fit our bolt pattern. The holes will not be centered on the studs, but since that generation of F150 has hub-centric rims instread of lug-centric, the wheel will center itself on our hubs since they are the same size. Because the rims are 9.5 wide, I am running a custom hub-centric, 2" wide, 5-5.5" spacer on the rear (ebay) and had to grind off about an 1/8" of the lower outer edge of the tie rod so they don't rub in the front. I don't think the fronts would rub if it where at stock height, its the dream beam tie rod relocators that got me. I also had to get lug nuts with a flat backside (not tapered).
There are quite a few first generation lightning (early 90's) owners runnin these without problems, so since we share the same bolt patter I figured it was worth a try.
- Joshpow
cool info there! Looks great. Good luck.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
My 69 F100 by me
Engine is a GT super car alloy 5.4ltr block GT quad cam heads wet sump 11.5 to 1 comp motec ecu. 6spd tremec. winters quick change rear end. rims centerline autodrags 15x7 front 15x12 rear.
- F100builder
Nice ride man...nice ride.
Patrick
- marvin2
...Holy crap!my69f100 wrote:Engine is a GT super car alloy 5.4ltr block GT quad cam heads wet sump 11.5 to 1 comp motec ecu. 6spd tremec. winters quick change rear end. rims centerline autodrags 15x7 front 15x12 rear.
- 1970Custom
Re: bumps with lowerd altitude!! (pics please)
What size tires you running? I love this truck...
Hi, I'm Eric and I have a bumpside addiction.
- texrodder
MY 71 GETTING READY TO LEAVE FOR THE BODY SHOP
- F100builder
Middleton huh? Have I seen you around? What's your truck look like?1970Custom wrote:What size tires you running? I love this truck...
Patrick
- F100builder
Why would anyone have a black truck with red wheels?!!
So, what color are you going with for the new paint?
Patrick
