Brake lines from master cylinder
BayStYAt
Post by BayStYAt »
I am looking to purchase the two pre bent hard brake Lines that mount at the master cylinder. I cant seem to find what i need.
I have a 1971 F100 2wd with power drum brakes
any help is appreciated
Thanks
Ranchero50
Re: Brake lines from master cylinder
Post by Ranchero50 »
Stop by NAPA and buy some 3/16" plastic coated steel tubing and a flaring tool. You'll need to reuse some of the fittings. Youtube how to flare and have at it.
Ohiotinkerer
Post by Ohiotinkerer »
https://www.inlinetube.com
This is where I got mine for my 68 after I switched over to power brakes........had to change one fitting but other than that fit and worked perfect...... :thup:
1997 Honda CBR 900RR
bochyhawg
Post by bochyhawg »
The old fittings are hard to find. I’ve had a flaring kit for twenty years. It works for fuel lines and leaks in copper water pipes. There is also a tool called “tube cutter”. I paid about $2 a foot for the 3-16” copper brake line.
BayStYAt
Post by BayStYAt »
awesome thanks y'all
BobbyFord
Post by BobbyFord »
3/16” Bundy tube brake line is what you want. Easy to bend with an Imperial tube bender.
BayStYAt
Post by BayStYAt »
