1966 F100 brake lines on 1969 F250
Fordinblue20
Post by Fordinblue20 »
Does anyone know if a longbed 1966 F100 brake lines will fit a longbed 1969 F250?
Busboy
Re: 1966 F100 brake lines on 1969 F250
Post by Busboy »
I've got access to the complete metal brake lines off of a 69 F-250 if your interested.
1967 F-100 4x4 custom cab.
Fordinblue20
Busboy wrote:I've got access to the complete metal brake lines off of a 69 F-250 if your interested.
I am interested! Please tell me more. The one on my 69 has officially died as well as the valve but I’m going to get the valve off a f100 with drum brakes. Hopefully the valve is the same at least.
Busboy
Post by Busboy »
So it's a 69 f-250 2wheel drive long bed with drums on the front or discs on the front? I either already have the correct valve or can get it.
Fordinblue20
Busboy wrote:So it's a 69 f-250 2wheel drive long bed with drums on the front or discs on the front? I either already have the correct valve or can get it.
Yes, It’s a 2WD 1969 F250 longbed with drums all the way around.
Busboy
Post by Busboy »
Ok, I'll private message you.
