Full frame swap
Arrowhead2003
Full frame swap
Post by Arrowhead2003 »
Wasn’t exactly sure where to post this or if it’s allowed on here but I’m asking. I’m putting a 1967 f100 on a 2006 crown Victoria frame. I’m having problems mounting the pedal and booster and was wondering if anyone on here had ever done a swap and if so how did you set up the brakes.
1970 f100 Ranger lwb
Ranchero50
Re: Full frame swap
Post by Ranchero50 »
Use the truck power brake booster and widen the mounting holes on the newer master cylinder to fit. Plumb new lines as needed.
Arrowhead2003
Re: Full frame swap
Well I thought about that for hours and it was just that simple, well anyways one more question, I want to use the original column, how would you go about the steering shaft?
