yellowish fluid leak rear hub
gritlight
Post by gritlight »
Originally I thought the leak must be break fluid but the reservoir is completely full still.
A good bit of it leaks from the center of the right rear wheel each time its driven. Its pretty sticky stuff.
Does any one have a lock on what this is? what should my next step be? Thank you and excuse my ignorance im still learning!
RottenAppleRed
Re: yellowish fluid leak rear hub
Post by RottenAppleRed »
Is there any water envolved?...rain, puddle, car wash? Is it possible that your rear axl housing has water in it? Water and 90w gear oil, mixed by a churning differential makes a sticky, yellow froth. An over full rear housing contaminated with water, could produce a leak from the axl seal. Other than that, I'd say wheel cylinder?
chriscris
Post by chriscris »
Yes, check you axle seals.
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
