302 vs 360 suspension
dtcohen
Post by dtcohen »
hi all,
I am looking at a 1970 F100 short wheelbase truck. It currently has a 302 which does not run and might be locked up. If I purchase the truck I would like to swap in a 360. Is there any difference in the suspension between a small block and big block truck?
Daniel
Ranchero50
Re: 302 vs 360 suspension
Post by Ranchero50 »
Other than springs and maybe wider front brakes I don't think so.
71Fe2O3
Post by 71Fe2O3 »
As far as I know, the brakes and suspension are the same regardless of engine size.
Fred
dtcohen
Post by dtcohen »
So the springs might be different? I know the fe engine is going to weigh about 200lb more than the 302. I know that old mustangs had different springs depending on whether the car had a 6cyl or a v8. Thought the trucks might be the same.
ultraranger
Post by ultraranger »
A '67 F100 will have 11" x 2" front drum brakes and 11" x 1-3/4" rear drum brakes. The '68-'72 F100s will have 11" x 3" front drums and 11" x 2-1/4" rear drums.
dtcohen
Post by dtcohen »
Thanks for the info guys!
