Post your 4X4 pictures HERE!!
Sheepdog
Re: Post your 4X4 pictures HERE!!
Post by Sheepdog »
Nice Highboy, Johnny. What size/brand tires are you running? Care to share any more specifics on the truck?
1969 F250 4X4
360 V8, C6 auto trans
small lift, 36x12.5x16.5 military tires
johnnyshaner
Post by johnnyshaner »
Tires are Power King 235 85 16 (radials). I haven't been able to find any online, so I'm not sure if they still make them. Truck is a 68 with the Ranger trim, 360 and a 4-speed. It's a former Oregon truck, so there's not much rust.
dougster
Post by dougster »
71 F250 4x4 Highboy. Just finishing up the interior; exterior more/less complete. Had this truck for 20 years now. Factory lime gold metallic (done in base/clear). Tires are 255/85/16's
jdf
Post by jdf »
that's a super nice truck ............ the 71 was my favorite year I really like the 71 grilles that's what I started with was a 71 highboy but the isn't much of the original truck left now other then the title lol I put a 1995 1 ton 4x4 frame and axles under it and have replaced every body part there was to change but when its done it will still look like a 71 highboy but drive like a 95 model ....... anyway you got a cool truck there definitely one to be proud of
KRob
Post by KRob »
Frankin Ford, had to throw the chains on today and still took a few more running tries to get through.
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
67fordtruck
Post by 67fordtruck »
Ok, Ill play.
Just picked up this 68, pulled from a field after sitting for about 10 years.
Used the carb and voltage regulator off the 67 crew to get it running. So far, gas, a starter and starter cable are all it needed to be running around the ranch.
The kicker is it has a factory 5 lug Dana 60, 3:54 geared posi(which worked really well!) Cab is toast and still deciding what to do with her. I have another 68 cab, just not sure if I will swap it on or not.
-1967 F-250 Crew Cab Short Bed
-1975 Jeep CJ5, Daily
fordguy_78
Post by fordguy_78 »
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
460 crew
Post by 460 crew »
That looks tough!
brownac1983
Post by brownac1983 »
WHITEY FORD
Korupt Oprative
Post by Korupt Oprative »
1970 F250
fordguy_78
Flex pics, and yes I like picture whoring my stuff
Phill
78 Mustang
67 F250ish
CrypticRacer13
Post by CrypticRacer13 »
Love it Phill, you have a build tread on Pirate or anything?
-Mike-
ECV 1849
fordguy_78
full size bronco as that's what it's chassis started life as http://fullsizebronco.com/forum/showthr ... 647&page=1 and all my pics http://www.supermotors.net/registry/24687
Phill
78 Mustang
67 F250ish
hazelnut
Post by hazelnut »
Since it's my birthday i thought i would put some trim on the truck to see how it's going to look when done. Wish i had the 35s for the polished slot rims ive got for it.
Florian
Post by Florian »
Awesome stance! Love how the tires stick out, looks aggressive! 8)
1971 Ford F100, 302cui, 3 on the tree
