bumps with lowered altitude!! (lots of great custom bumps!!)
- Fordfrk195
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Finally got around to dropping the truck some.
Before
After
Did a half shakle flip on the rear. The po had cut the front coils already but I cut another chunk out of the front right just to even the front out. Much better now got that I got the rake out of it, that with new rear shocks and it drives way better.
Before
After
- F100builder
Looks great!
Patrick
- michael69
You have my twinFordfrk195 wrote:Finally got around to dropping the truck some.
Before
[ Image ]
After
[ Image ]
[ Image ]
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- Fordfrk195
Looks like it. Your looks to be in much nicer shape.
- BrotherMabe
- BrotherMabe
^^ that looks great!
I want to erase the hood seem also. How did you do that? Weld it up??
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
'66 bronco
'68 bronco
it's the best way. if you use filler it's prone to cracking.
1967 f100 stepside 300ci I6
1972 longbed trailer
That's awesome brother mabe! How did you lower it?
- BrotherMabe
Thanks Phil!Hotrodphil wrote:That's awesome brother mabe! How did you lower it?
I lowered the entire truck with the DJM Suspension lowering kit, which lowers it 3" in the front (Lowering I-beams), and 4" in the rear with the shackles and hangers.
But then, as I looked at the truck it just didn't look low enough for me.
So I then took two of the five leaf springs out of the rear.
I took out the second and fourth, leaving the main spring (top) along with the helper spring (bottom) with one between them both.
And it lowered the rear 2 more inches.
I then proceeded to replace my big block springs with small block (six cylinder) springs to lower the front.
However the front still wasn't level with the rear, so reluctantly I cut the front springs 1/2 coil at a time, ending up with cutting a full coil out of each side.
I am looking to run a staggered set of rims. (Torque Thrust II or Riddler 645 or Streeter ShowWheels)
18 X 8 (245/40/18) on the front
10 X 20 (295/40/20) on the rear
- Speedpin
72 XLT
Spring over axle
Crown vic front springs with bowed factory I beams
5x5.5 to 5x4.5 wheel adapters, 1.25 inch thick.
17x8 factory Mustang Bullitt wheels with 245 45 tires. Soon to be 18x10 deep dish bullitts in rear with 295 45 .
Spring over axle
1968 f100 Ranger
Body swap over 02 Lightning, 5.4, Auto
Did you "bow" the i-beams yourself or did you take it to a shop to do it?Speedpin wrote:72 XLT
Spring over axle
- Speedpin
Shop did it. Older alignment place.
1968 f100 Ranger
Those places are harder & harder to find these days.Speedpin wrote:Shop did it. Older alignment place.
