bumps with lowered altitude!! (lots of great custom bumps!!)
Calfdemon
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Post by Calfdemon »
Damn Marz!! That thing looks so different with the front bumper and a hood on it!! The truck is looking good! You are making a lot of progress on it! :thup:
-Rich
Current toys -
Former toys -
marz68
Post by marz68 »
Calfdemon wrote:Damn Marz!! That thing looks so different with the front bumper and a hood on it!! The truck is looking good! You are making a lot of progress on it! :thup:
Thanks calfdemon.
I've done more to it in the past two months than I did all of last year. :D
Dave Maxwell
Post by Dave Maxwell »
Thanks. Looks killer
ezernut9mm
Post by ezernut9mm »
finished the 70. it's not low enough, but it's the best i can do for free.
F100builder
Post by F100builder »
Looking good ezernut! What all did you do to get it as low as you did? How many coils? :thup:
Marz, is that thing 4WD?! If not, you should think about gettin' that thing DOWN... :wink: Looks great man!
Patrick
ezernut9mm
two coils in front and the hanger flip in back. i think i'm gonna add some lowering shackles to get two more inches.
Dr Casti
Post by Dr Casti »
ezernut9mm wrote:two coils in front and the hanger flip in back. i think i'm gonna add some lowering shackles to get two more inches.
Don´t you have any trouble with the pinion angle? I did this with mine and the pinion angle was incorrect, thus the differential was giving me some noise. Had to go back and unflipped the hanger again. Someone suggest me that need to cut a bit the cardan shaft, um not sure to do this.
1969 Ford F-250 Camper Special. 360 V8, C-4 auto.
Dr Casti
Post by Dr Casti »
Here´s my 69 F-250CS with 20 inch wheels.
ezernut9mm
when i install the lowering shackles in the rear it will level out the diff again. you can buy pinion angle shims for about 20$. i had to shim the pinion on the 68i lowered. this one isn't correct, but it hasn't given me any trouble yet....yet. lol
F100builder
Yeah, I put 4 degree shims on the leaf spring saddles to get the proper angle back when I flipped my hangers.
Ezer, can the DJM lowering shackles be used on the Flexomatics?
Patrick
ezernut9mm
nope. at least not that i know of. the spring is too long. finding a non flexo main spring should be pretty easy.
1971 F100
Post by 1971 F100 »
ezernut9mm wrote:nope. at least not that i know of. the spring is too long. finding a non flexo main spring should be pretty easy.
I have the FOM rear springs and the DJM shackles and front spring hangers worked fine.
1971 F100
Post by 1971 F100 »
My truck is the Orange and White truck on page 76 of this forum. I was also concerned about the longer spring but after some research and test fitting it worked fine.
ezernut9mm
i'd like to see pics. not because i don't believe you, but because i don't see how it would work.
1971 F100
Post by 1971 F100 »
ezernut9mm wrote:i'd like to see pics. not because i don't believe you, but because i don't see how it would work.
My truck is in storage for the winter months I will see what can dig up, but had to remove everything from the rear spring eye and install the DJM shackle. There are other trucks on this site that have the same set up.
