bumps with lowered altitude!! (lots of great custom bumps!!)
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
NOOOOOOO! I just reached the end of this thread after having gone through every single page.
I just lowered the rear end of my 72 about 3 inches with new drop hangers for the front mount on the leaf spring. Nothing to major but i wanted my truck to look leveled out. I have new Ford rally wheels with 255/65/15 Cooper tires getting mounted next week. Should look good.
- shoots
Finally got the bed back on.
1972 Sport Custom 400/FMX
I love the red rims!!shoots wrote:Finally got the bed back on.
Finally got the hood put on, and lined up. So, I figured Id post up a few last pics.
11' Lexus Is350- daily
10' Infiniti fx35- daily
99' Mustang GT- Fully Built, Supercharged 4v
93' Cobra-
91' Coupe-
67- F100
93' Cobra-
91' Coupe-
67- F100
Looks perfect filthy!
Details on your running gear/suspension ?
Wheel size and backspace?
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
'66 bronco
'68 bronco
Getting back on my 67 short wide. Started out with a set of dropped beams but was getting as low as i wanted. Truck is getting a twin turbo Aluminum 5.3 LS1.
I will be selling the dropped beams - trailing arms w/ brakes and all soon. If interested PM me. make you a swing'n deal.You do not have the required permissions to view the files attached to this post.
I was with you till this ^^67f1dragger wrote: Truck is getting a twin turbo Aluminum 5.3 LS1.
Good lookin' truck otherwise....
'66 bronco
'68 bronco
'66 bronco
'68 bronco
Here are some good pics. Im going for a a similar look as these two
1968 F100 reg cab long bed
1977 F150
2005 Explorer
1977 F150
2005 Explorer
Im going satin black 3/4 drop with vintage wheel reproduction 15x7 front and 15x10 rear factory style steel wheels with moon caps.
1977 F150
2005 Explorer
1977 F150
2005 Explorer
Broncobilly66 wrote:Looks perfect filthy!
-396 w/ heads, cam, intakes/ Built C6
-AIM Lowering Beams, and Shackle kit
-Wheels are AR torque Thrust II 20x9, and 20x9.5 (Backspace is 4.25")
93' Cobra-
91' Coupe-
67- F100
93' Cobra-
91' Coupe-
67- F100
- BobbyFord
- michael69
Also did you find someone that had your rims or did you special order them. I am wanting to run 18" torq thrust two's and can't find anyone that sells 5 on 5.5 bolt pattern. Have been told will have to special order and it will take 3-4 months at the least to get them. You mind telling where you got yours. Love your truck.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
